Home » Eclipse Projects » EGit » Operation not supported - Internal Error(Problems with Egit on Zend Studio Mac OSx)
Operation not supported - Internal Error [message #492233] Mon, 19 October 2009 10:33 Go to next message
No real name is currently offline No real name
I am trying to switch from SVN to Git and the Egit Eclipse solution is
the one I chose to use with Eclipse. I am developing on Zend Studio,
Eclipse based, under Mac OSX but I am having troubles with Egit.
The main issue is that I can't commit or perform tasks like moving
deleting (which btw with the Egit seems pretty nice, editing
references inside the files on the fly, very usefull)
So the main problem is when I try to remove/move some files I get this message and options ot abort or undo:
"Problems encountered while moving resources.
Error updating cache during move/delete.
The resource cannot be moved, renamed or deleted due to an internal error.
Operation not supported"
When I try to Commit I also get the Operation not supported msg.
The funny thing is if I commit through Opengit or Terminal I can then
push through Egit.
Any help is appriciated
thanx
Re: Operation not supported - Internal Error [message #504048 is a reply to message #492233] Wed, 16 December 2009 17:35 Go to previous message
Matthias Sohn is currently offline Matthias Sohn
Which version of EGit are you using ?
Previous Topic:Distributed Alternatives
Next Topic:Operation not supported - Internal Error
Current Time: Mon May 20 20:49:36 EDT 2013
Powered by FUDForum. Page generated in 0.01864 seconds
