| Re: XML generation from XSD puts "token" in attributes [message #503260 is a reply to message #498859] |
Fri, 11 December 2009 11:03  |
Valentin Messages: 36 Registered: July 2009 |
Member |
Nick, yes there are some limitations in the WTP XSD to XML instance
generator.
I have opened this bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=297594 to track the problem.
Valentin
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:he1jc9$1k3$1@build.eclipse.org...
> Nick,
> The XSD project doesn't provide that action. Maybe the web tools project
> does. I've added it to the "to" list of the reply.
> Nick Radov wrote:
>> I would like to generate some sample XML files for testing based on an
>> XSD. So I used the "Generate, XML File..." command and it did create a
>> file. Unfortunately, many of the attributes in the generated file are set
>> to "token" which doesn't pass schema validation. The XSD defines a
>> limited set of allowable values for those attributes.
>> Is there any way to make it generate correct attribute values?
>> Unfortunately I can't post the XSD files here to reproduce the problem
>> because they are copyright by HL7. If anyone happens to be an HL7 member
>> you can download the CDA.xsd file from the
>> http://www.hl7.org/implement/standards/cda.cfm page in the "CDA Release
>> 2" package.
| Re: XML generation from XSD puts "token" in attributes [message #604439 is a reply to message #498859] |
Member |
generator.
Valentin
> Nick,
>> 2" package.
FUDForum. Page generated in 0.01900 seconds
