Home » Eclipse Projects » Eclipse Platform » Dialog to open files in workspace
Dialog to open files in workspace [message #502777] Wed, 09 December 2009 11:42 Go to next message
Vsevolod Sandomirskiy is currently offline Vsevolod Sandomirskiy
org.eclipse.ui.dialogs.SaveAsDialog provides file selection in the
workspace. Is there a similar OpenDialog? I couldn't find one.
org.eclipse.swt.widgets.FileDialog shows the whole filesystem, not the
workspace.
I could use ElementTreeSelectionDialog with WorkbenchContentProvider,
but there must be an easier way.
Thanks.
Re: Dialog to open files in workspace [message #502798 is a reply to message #502777] Wed, 09 December 2009 12:27 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.
> workspace.
Open Resource Dialog (Ctrl+Shift+R) is what you looking for?
- Prakash
Platform UI Team, IBM
Blog <http://blog.eclipse-tips.com>
Twitter <http://www.twitter.com/Eclipse_Tips>
Re: Dialog to open files in workspace [message #502995 is a reply to message #502777] Thu, 10 December 2009 09:35 Go to previous message
Eric Rizzo is currently offline Eric Rizzo
> workspace.
That route is actually pretty simple. Here is an example to give you a
head-start (note, this code is licensed under GPL 3):
< http://www.skywayperspectives.org/fisheye/browse/CVS_OpenSou rce/skyway/common/plugins/org.skyway.core.ui/src/org/skyway/ core/ui/dialogs/ProjectFileSelectionDialog.java>
Hope this helps,
Eric
Previous Topic:new version cvs do not update recursively
Next Topic:ViewerCell.getColumnIndex() Returns Different Values When Detached
Current Time: Sat May 18 18:53:17 EDT 2013
Powered by FUDForum. Page generated in 0.01645 seconds
