Home » Eclipse Projects » Web Tools Project (WTP) » Could not initialize class org.eclipse.wst.wsdl.WSDLPackage$Literals(Error with WSDL files)
Could not initialize class org.eclipse.wst.wsdl.WSDLPackage$Literals [message #502917] Thu, 10 December 2009 05:21 Go to next message
Krige Mising name is currently offline Krige Mising name
I am using Eclipse 3.5.1 under Ubuntu 9.10. I have installed the Eclipse Web Developers Tools.
When I try to open a WDSL file I get the following error:
An error has occurred.
See error log for more details.
Does anyone know what the problem could be?
Re: Could not initialize class org.eclipse.wst.wsdl.WSDLPackage$Literals [message #502989 is a reply to message #502917] Thu, 10 December 2009 09:19 Go to previous messageGo to next message
Valentin is currently offline Valentin
Member
Hi, is there any more information in the error log? You can check the log
using the Error log view or directly in the file <workspace
location>/.metadata/.log.
"Krige" <marco.lackovic@gmail.com> wrote in message
news:hfqi3s$45m$1@build.eclipse.org...
Re: Could not initialize class org.eclipse.wst.wsdl.WSDLPackage$Literals [message #503438 is a reply to message #502989] Sun, 13 December 2009 22:07 Go to previous messageGo to next message
Hi, thanks for your reply Smile
The log pertaining to the error is the following:
!ENTRY org.eclipse.jface 4 2 2009-12-14 10:01:15.851
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.ExceptionInInitializerError
	at org.eclipse.wst.wsdl.WSDLPackage$Literals.<clinit>(WSDLPackage.java:3696)
	at org.eclipse.wst.wsdl.internal.impl.DefinitionImpl.eStaticClass(DefinitionImpl.java:295)
	at org.eclipse.emf.ecore.impl.EObjectImpl.eClass(EObjectImpl.java:224)
	at org.eclipse.emf.ecore.impl.ENotificationImpl.getFeature(ENotificationImpl.java:223)
	at org.eclipse.wst.wsdl.internal.impl.WSDLElementImpl.eNotify(WSDLElementImpl.java:379)
	at org.eclipse.wst.wsdl.internal.impl.DefinitionImpl.eNotify(DefinitionImpl.java:515)
	at org.eclipse.wst.wsdl.internal.impl.DefinitionImpl.setLocation(DefinitionImpl.java:341)
	at org.eclipse.wst.wsdl.internal.impl.DefinitionImpl.setDocumentBaseURI(DefinitionImpl.java:1135)
	at org.eclipse.wst.wsdl.ui.internal.text.WSDLModelAdapter.createDefinition(WSDLModelAdapter.java:109)
	at org.eclipse.wst.wsdl.ui.internal.InternalWSDLMultiPageEditor.createAndSetModel(InternalWSDLMultiPageEditor.java:151)
	at org.eclipse.wst.wsdl.ui.internal.InternalWSDLMultiPageEditor.buildModel(InternalWSDLMultiPageEditor.java:118)
	at org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.buildAndSetModel(ASDMultiPageEditor.java:173)
	at org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.createPages(ASDMultiPageEditor.java:149)
	at org.eclipse.wst.wsdl.ui.internal.InternalWSDLMultiPageEditor.createPages(InternalWSDLMultiPageEditor.java:406)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:357)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:286)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2857)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:361)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:168)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:208)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:250)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:373)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:526)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
	at org.eclipse.core.runtime.Platform.run(Platform.java:895)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3493)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3112)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.NullPointerException
	at org.eclipse.wst.wsdl.internal.impl.WSDLPackageImpl.init(WSDLPackageImpl.java:526)
	at org.eclipse.wst.wsdl.WSDLPackage.<clinit>(WSDLPackage.java:84)
	... 74 more
!ENTRY org.eclipse.wst.xml.core 4 4 2009-12-14 10:01:15.889
!MESSAGE Exception loading CMDocumentFactory
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.wst.xsd.core" was unable to instantiate class "org.eclipse.wst.xsd.contentmodel.internal.CMDocumentFactoryXSD".
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:180)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:172)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:874)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
	at org.eclipse.wst.xml.core.internal.contentmodel.factory.CMDocumentFactoryDescriptor.getFactory(CMDocumentFactoryDescriptor.java:35)
	at org.eclipse.wst.xml.core.internal.contentmodel.factory.CMDocumentFactoryRegistry.getFactory(CMDocumentFactoryRegistry.java:51)
	at org.eclipse.wst.xml.core.internal.contentmodel.ContentModelManager.createCMDocument(ContentModelManager.java:55)
	at org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimpl.CMDocumentManagerImpl.buildCMDocument(CMDocumentManagerImpl.java:267)
	at org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimpl.CMDocumentManagerImpl$1.run(CMDocumentManagerImpl.java:239)
	at org.eclipse.wst.xsd.contentmodel.internal.CMDocumentFactoryXSD.<init>(CMDocumentFactoryXSD.java:30)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
	at java.lang.Class.newInstance0(Class.java:355)
	at java.lang.Class.newInstance(Class.java:308)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:170)
	... 9 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2009-12-14 10:01:15.890
!MESSAGE Plug-in "org.eclipse.wst.xsd.core" was unable to instantiate class "org.eclipse.wst.xsd.contentmodel.internal.CMDocumentFactoryXSD".
!STACK 0
!ENTRY org.eclipse.wst.xml.core 4 4 2009-12-14 10:01:15.891
!STACK 1
	... 9 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2009-12-14 10:01:15.892
!STACK 0
!ENTRY org.eclipse.osgi 2 1 2009-12-14 10:01:16.630
!MESSAGE NLS unused message: missingOneOfTwoAttributes in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: categoryNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: actionNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: actionAlreadyDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2009-12-14 10:01:16.631
!MESSAGE NLS unused message: presetNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: templateNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: invalidActionType in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: invalidEventHandlerType in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: invalidRequiresConstraint in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2009-12-14 10:01:16.632
!MESSAGE NLS unused message: invalidConflictsConstraint in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: deprecatedRuntimeChangedAction in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: tracingActionSorting in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: tracingFrameworkActivationStarting in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS unused message: tracingFrameworkActivationFinished in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2009-12-14 10:01:16.633
!MESSAGE NLS missing message: problemCaseNotRecognized in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!MESSAGE NLS missing message: runtimeComponentTypeNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2009-12-14 10:01:16.633
!MESSAGE Project facet jst.web has not been defined. It is used in plugin org.eclipse.wst.jsdt.web.core.
Re: Could not initialize class org.eclipse.wst.wsdl.WSDLPackage$Literals [message #503955 is a reply to message #503438] Wed, 16 December 2009 10:46 Go to previous message
Raymond Lai is currently offline Raymond Lai
What's the default JDK/JRE on your system? Can you try JDK 1.5/1.6?
Previous Topic:Problems using the org.eclipse.wst.ws.internal.explorer package
Next Topic:Re: Does XML Schema editor work with CCRC?
Current Time: Tue May 21 02:17:27 EDT 2013
Powered by FUDForum. Page generated in 0.01786 seconds
