| Re: Help to build SWT JNI libraries [message #503092 is a reply to message #502839] |
Thu, 10 December 2009 10:22  |
Grant Gayed Messages: 2128 Registered: July 2009 |
SWT uses "Windows Server 2003 SP1 SDK" to compile its Windows libraries for
x86_64. This SDK is available from microsoft as a free download, so I think
your easiest path is to just get it and try it. I'm sure that VC9 could be
used as well, but this may require making some changes in make_win32.mak.
setenv is setenv.cmd, which ships with the SDK. It sets up your environment
for compiling.
Grant
"Yura" <yzhishko@exadel.com> wrote in message
news:hfp3bn$rg3$1@build.eclipse.org...
> Hi. I need to build JNI libraries under win x86_64 platform as was said in
FAQ:
> http://eclipse.org/swt/faq.php#howbuilddll
> I've got some questions:
> 1) Which versions of compilers I can use? I want to make an attempt with
vc 9 integrated with MVS 2008, does it suit?
> 2) In build.bat file I've found next line in :x86_64 section:
> call %MSSDK%\setenv /X64 /RETAIL
> I suppose that in this line we try to call setenv function using
setenv.bat from WDK (http://msdn.microsoft.com/en-us/library/ms792423.aspx),
don't we?
> Thanks.
FUDForum. Page generated in 0.01622 seconds
