Home » Eclipse Projects » Web Tools Project (WTP) » Re: Does XML Schema editor work with CCRC?
Re: Does XML Schema editor work with CCRC? [message #502820] Wed, 09 December 2009 14:07 Go to next message
Ed Merks is currently offline Ed Merks
Grace,
Maybe it's a WTP question. I've added it to the "to" list of the
reply. It it reproducible without Clearcase?
gracehylo@yahoo.com wrote:
> Thanks Ed.
> I installed Clearcase Remote Client 7.1.1. Then I create a new .xsd
> and checked into the repository.
> Then I open using the "XML Schema editor".
> After I tried to use "Add Element" to add an XSDElement,
> and save the xsd, I get these problems.
> Which forum category should it belong? Thanks.
> Grace
Re: Does XML Schema editor work with CCRC? [message #503080 is a reply to message #502820] Thu, 10 December 2009 14:36 Go to previous messageGo to next message
No real name is currently offline No real name
Thanks.
It is working fine without clearcase.
Grace
Re: Does XML Schema editor work with CCRC? [message #503968 is a reply to message #502820] Wed, 16 December 2009 11:12 Go to previous message
Raymond Lai is currently offline Raymond Lai
Hi Grace,
Do you have relevant logs in .metadata/.log? Are the files checked out as read-only or locked?
Ray
Previous Topic:Could not initialize class org.eclipse.wst.wsdl.WSDLPackage$Literals
Next Topic:Eclipse, WTP, OSX, Tomcat, Tiles, JSP not found... deploy from Eclipse
Current Time: Fri May 24 10:19:14 EDT 2013
Powered by FUDForum. Page generated in 0.01808 seconds
