| Does XML Schema editor work with CCRC? [message #502752] |
Wed, 09 December 2009 10:49  |
No real name Messages: 6 Registered: November 2009 |
Junior Member |
I do not know which forum to put this to.
When using the XML Schema editor in Clearcase remote client, I see this exception:
==> An error has occurred. See error log for more details.
!ENTRY org.eclipse.ui.views.properties.tabbed 4 2 2009-12-09 08:34:57.151
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.views.properties.tabbed".
!STACK 0
at org.eclipse.xsd.util.XSDConstants.lookupQualifier(Unknown Source)
at org.eclipse.xsd.impl.XSDNamedComponentImpl.getQName(Unknown Source)
at org.eclipse.wst.xsd.ui.internal.common.properties.sections.X SDComplexTypeSection.fillTypesCombo(Unknown Source)
at org.eclipse.wst.xsd.ui.internal.common.properties.sections.X SDComplexTypeSection.refresh(Unknown Source)
at org.eclipse.ui.views.properties.tabbed.TabContents$6.run(Unk nown Source)
at org.eclipse.core.runtime.SafeRunner.run(Unknown Source)
at org.eclipse.core.runtime.Platform.run(Unknown Source)
at org.eclipse.ui.internal.JFaceUtil$1.run(Unknown Source)
at org.eclipse.jface.util.SafeRunnable.run(Unknown Source)
at org.eclipse.ui.views.properties.tabbed.TabContents.refresh(U nknown Source)
at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPa ge.refresh(Unknown Source)
I wonder if it is supported.
Grace
| Re: Does XML Schema editor work with CCRC? [message #502814 is a reply to message #502775] |
Wed, 09 December 2009 14:07  |
Ed Merks Messages: 24553 Registered: July 2009 |
Grace,
Maybe it's a WTP question. I've added it to the "to" list of the
reply. It it reproducible without Clearcase?
gracehylo@yahoo.com wrote:
> Thanks Ed.
> I installed Clearcase Remote Client 7.1.1. Then I create a new .xsd
> and checked into the repository.
> Then I open using the "XML Schema editor".
> After I tried to use "Add Element" to add an XSDElement,
> and save the xsd, I get these problems.
> Which forum category should it belong? Thanks.
> Grace
| Re: Does XML Schema editor work with CCRC? [message #604433 is a reply to message #502768] |
Wed, 09 December 2009 11:42  |
Junior Member |
Thanks Ed.
I installed Clearcase Remote Client 7.1.1. Then I create a new .xsd and checked into the repository.
Grace
| Re: Does XML Schema editor work with CCRC? [message #604435 is a reply to message #502775] |
Grace,
> Thanks Ed.
> Grace
FUDForum. Page generated in 0.01716 seconds
