| Re: Bug prediction using past testing effort [message #504147 is a reply to message #504063] |
Thu, 17 December 2009 07:35  |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
Each source class should have a unique package name space. However, class
names can be reused.
Paul
"Aleem Alvi" <akalvi@gmail.com> wrote in message
news:hgbsrc$6sq$1@build.eclipse.org...
> Hi Paul,
> Thank you for your reply. I would like to know that "has Eclipse source
> code class unique name? Means if we consider LaunchURL.java class
> available on following path
> \\src\plugins\org.eclipse.help.ui\src\org\eclipse\help\ui\br
> owser\LaunchURL.java
> THEN no other class in whole Eclipse source code base with
> "LaunchURL.java" name.
> If yes then is this true also for the Automated test for example
> eclipse-Automated-Tests-2.1.zip is available on Eclipse archive including
> java test classes.
> Thanks and best regards,
> Aleem Alvi
FUDForum. Page generated in 0.02364 seconds
