Home » Eclipse Projects » Eclipse Platform » Weird button behavior (Click doesn't work)
Weird button behavior [message #498620] Tue, 17 November 2009 11:59 Go to next message
Nathan Baker is currently offline Nathan Baker
After upgrading to KDE 4.3 I am seeing weird behavior in some modal dialogs (generally ones that require more input than just a button press, such as the Open Resource dialog). When I click on the 'OK' button, nothing happens. If I move the focus to a different button with the tab key and then click the button, still nothing happens. But if I tab to the button and press enter, it accepts it.
I thought this might be a problem with KDE itself, but I don't see this behavior in any other apps. It might be a problem with the JVM, but I don't really use any other Java programs.
Has anyone else seen this behavior? Does anyone know how to correct it?
Nathan
Re: Weird button behavior [message #498638 is a reply to message #498620] Tue, 17 November 2009 14:08 Go to previous messageGo to next message
Seems like it might be a GTK issue...I solved it through the method described here.
Re: Weird button behavior [message #498754 is a reply to message #498638] Wed, 18 November 2009 09:51 Go to previous messageGo to next message
OK, I was wrong again. I thought those steps fixed it, but apparently the problem is just intermittent.
I also note that other people running OpenSUSE are seeing this problem as well:
http://forums.opensuse.org/applications/425503-opensuse-11-2 -heap-trouble-eclipse-ide-2.html#post2070204
Nathan
Re: Weird button behavior [message #498886 is a reply to message #498754] Wed, 18 November 2009 19:14 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
> as well:
> Nathan
Setting the GDK_NATIVE_WINDOWS=true environment variable is working for
me on Ubuntu Karmic.
Re: Weird button behavior [message #501969 is a reply to message #498620] Fri, 04 December 2009 10:50 Go to previous messageGo to next message
Roland Brand is currently offline Roland Brand
Member
Hi Nathan
I'm almost sure, you're describing this bug here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=291257
Roland
Re: Weird button behavior [message #501978 is a reply to message #501969] Fri, 04 December 2009 11:09 Go to previous message
Roland,
Pretty sure you're right. For a while I tried the workaround and thought it didn't help, but now it seems to be working pretty consistently.
Thanks!
Nathan
Previous Topic:Problem deleting IProject
Next Topic:Update: new plugin version not visible -- where cached?
Current Time: Wed May 22 06:25:25 EDT 2013
Powered by FUDForum. Page generated in 0.01726 seconds
