| [AM3] New AM3 version compatible with ATL 3.x is now available from the project's SVN HEAD [message #501948] |
Fri, 04 December 2009 09:59  |
Hugo Bruneliere Messages: 467 Registered: July 2009 |
Hi all,
Just to let you know that the AM3 SVN HEAD now provides an AM3 version
compatible with ATL 3.x (however, the traceability features are still
currently not available due to current AMW compatibility issues).
So, for the people currently using the "ATLv3_0_Compatibility_dev"
branch, you should switch to the HEAD.
FYI, the previous version compatible with ATL 2.1 can still be obtained
from the "ATLv2_1_Compatibility" branch.
More information is available from
http://wiki.eclipse.org/AM3/How_Install_New_AM3_From_SVN
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN) - Room B206
Ecole des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
Office: +33 (0)2 51 85 82 21
EMail: hugo.bruneliere@inria.fr
AtlanMod research team (Inria, EMN & LINA)
Nantes - France
| Re: [AM3] New AM3 version compatible with ATL 3.x is now available from the project's SVN HEAD [message #580058 is a reply to message #501948] |
Wed, 30 June 2010 14:27  |
wafaa Messages: 163 Registered: January 2010 Location: Egypt |
hi ,
first of all thanks for this new version but there is a problem in the documentation you point to
1- for the repository location, it was not written as a link out of the image, we then have to write it by hands which is no suitable
2- second , it shows it using svn but eclipse versioen 3.5 have svs and it has different structure than svn
so could you please give us the following information of AM3 check out
Host
Repository path
as required by svs
FUDForum. Page generated in 0.01503 seconds
