Home » Modeling » UML2 Tools » Where are the UML2 Tools sample projects?
Where are the UML2 Tools sample projects? [message #501836] Thu, 03 December 2009 19:23 Go to next message
David M. Karr is currently offline David M. Karr
A while ago I happened to notice a large collection of sample projects and diagrams that could be created with UML2 Tools. I was able to check it out from a repo. I've lost the information about that. Where can I find that again?
Re: Where are the UML2 Tools sample projects? [message #501907 is a reply to message #501836] Fri, 04 December 2009 07:27 Go to previous messageGo to next message
Vlad Varnica is currently offline Vlad Varnica
[Updated on: Fri, 04 December 2009 14:06]
Report message to a moderator
Re: Where are the UML2 Tools sample projects? [message #501926 is a reply to message #501907] Fri, 04 December 2009 08:57 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Vlad,
Comments below.
Vlad Varnica wrote:
> Don't forget that UML is moving therefore if you have an example
> working with Eclipse 3.2 it could not work today.
It might rain today too.
> I definitely agree with the need to keep tracability
Relates to forgetting where the samples are located how?
> and don't really understand the usability value if thes permanent not
> needed changes at EMF & GMF levels
EMF and GMF levels relates to forgetting where the samples are how?
> which then change the UML and almost all the Eclipse modeling projects !!
This is even more off topic than the last two comments. Do you really
have nothing better to do?
What David appears to be asking for is a link to
http://wiki.eclipse.org/MDT-UML2Tools#Samples but you seem to use any
opportunity to go off on the same old tiresome tirade. It's worn thin
and with each iteration you undermine any shred of credibility you might
still have left.
Re: Where are the UML2 Tools sample projects? [message #501998 is a reply to message #501926] Fri, 04 December 2009 12:00 Go to previous messageGo to next message
Thanks, that's exactly what I needed.
Re: Where are the UML2 Tools sample projects? [message #625325 is a reply to message #501907] Fri, 04 December 2009 08:57 Go to previous messageGo to next message
Vlad,
Comments below.
still have left.
Re: Where are the UML2 Tools sample projects? [message #625329 is a reply to message #501926] Fri, 04 December 2009 12:00 Go to previous message
Previous Topic:Trying to define attribute in class in diagram of type "Set<ComponentType>"
Next Topic:Trying to define attribute in class in diagram of type "Set<ComponentType>"
Current Time: Sun May 19 08:58:04 EDT 2013
Powered by FUDForum. Page generated in 0.02506 seconds
