Home » Eclipse Projects » JFace » Problem using other than arrow keys for navigating TreeViewer
| Problem using other than arrow keys for navigating TreeViewer [message #501446] |
Wed, 02 December 2009 06:49 |
mvmsoft Messages: 11 Registered: July 2009 |
Junior Member |
We need a tree viewer navigating to next line on CR using 3.3+ API (tested on 3.4.1 and 3.5SR1. Overriding the CellNavigationStrategy seems to set the focus cell to the correct location, but since tree selection is not changed, it seems to be reset on the next getFocus() call. I guess the CellNavigationStrategy never works for up/down; trying left/right works.
This is a derivation of Snippet26 to show the problem; start it, expand some items, place focus on first cell, then press CR or 'd'; nothing happens. pressing arrow down works.
Any idea for a workaround ?
Marco
* Copyright (c) 2006, 2007 Tom Schindl and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Tom Schindl - initial API and implementation
package org.eclipse.jface.snippets.viewers;
import java.util.ArrayList;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.CellNavigationStrategy;
import org.eclipse.jface.viewers.ColumnLabelProvider;
import org.eclipse.jface.viewers.ColumnViewer;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationEvent;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
import org.eclipse.jface.viewers.EditingSupport;
import org.eclipse.jface.viewers.FocusCellOwnerDrawHighlighter;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.viewers.TreeViewerColumn;
import org.eclipse.jface.viewers.TreeViewerEditor;
import org.eclipse.jface.viewers.TreeViewerFocusCellManager;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Shell;
* A simple TreeViewer to demonstrate usage
* @author Tom Schindl <tom.schindl@bestsolution.at>
public class Snippet026TreeViewerTabEditingCR
public Snippet026TreeViewerTabEditingCR(final Shell shell)
Button b = new Button(shell, SWT.PUSH);
b.setText("Remove column");
final TreeViewer v = new TreeViewer(shell, SWT.BORDER | SWT.FULL_SELECTION);
v.getTree().setLinesVisible(true);
v.getTree().setHeaderVisible(true);
b.addSelectionListener(new SelectionListener()
public void widgetDefaultSelected(SelectionEvent e)
public void widgetSelected(SelectionEvent e)
v.getTree().getColumn(1).dispose();
TreeViewerFocusCellManager focusCellManager = new TreeViewerFocusCellManager(v,
new FocusCellOwnerDrawHighlighter(v), new CellNavigationStrategy()
public boolean isNavigationEvent(ColumnViewer viewer, Event event)
if (event.keyCode == SWT.CR || event.character == 'd')
return true;
return super.isNavigationEvent(viewer, event);
public ViewerCell findSelectedCell(ColumnViewer viewer,
ViewerCell currentSelectedCell, Event event)
if (currentSelectedCell != null)
return currentSelectedCell.getNeighbor(ViewerCell.ABOVE, false);
return super.findSelectedCell(viewer, currentSelectedCell, event);
public boolean shouldCancelEvent(ColumnViewer viewer, Event event)
return event.keyCode == SWT.CR || event.character == 'd'
|| super.shouldCancelEvent(viewer, event);
ColumnViewerEditorActivationStrategy actSupport = new ColumnViewerEditorActivationStrategy(
v)
protected boolean isEditorActivationEvent(ColumnViewerEditorActivationEvent event)
return event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType == ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON
|| event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC;
TreeViewerEditor.create(v, focusCellManager, actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL
| ColumnViewerEditor.KEYBOARD_ACTIVATION);
final TextCellEditor textCellEditor = new TextCellEditor(v.getTree());
TreeViewerColumn column = new TreeViewerColumn(v, SWT.NONE);
column.getColumn().setWidth(200);
column.getColumn().setMoveable(true);
column.getColumn().setText("Column 1");
column.setLabelProvider(new ColumnLabelProvider()
public String getText(Object element)
return "Column 1 => " + element.toString();
column.setEditingSupport(new EditingSupport(v)
protected boolean canEdit(Object element)
return false;
protected CellEditor getCellEditor(Object element)
return textCellEditor;
protected Object getValue(Object element)
return ((MyModel) element).counter + "";
protected void setValue(Object element, Object value)
((MyModel) element).counter = Integer.parseInt(value.toString());
v.update(element, null);
column.getColumn().setText("Column 2");
return "Column 2 => " + element.toString();
return true;
column.getColumn().setText("Column 3");
return "Column 3 => " + element.toString();
return true;
v.setContentProvider(new MyContentProvider());
v.setInput(createModel());
private MyModel createModel()
MyModel root = new MyModel(0, null);
root.counter = 0;
MyModel tmp;
MyModel subItem;
for (int i = 1; i < 10; i++)
tmp = new MyModel(i, root);
root.child.add(tmp);
for (int j = 1; j < i; j++)
subItem = new MyModel(j, tmp);
subItem.child.add(new MyModel(j * 100, subItem));
tmp.child.add(subItem);
return root;
public static void main(String[] args)
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new Snippet026TreeViewerTabEditingCR(shell);
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private class MyContentProvider implements ITreeContentProvider
public Object[] getElements(Object inputElement)
return ((MyModel) inputElement).child.toArray();
public void dispose()
public void inputChanged(Viewer viewer, Object oldInput, Object newInput)
public Object[] getChildren(Object parentElement)
return getElements(parentElement);
public Object getParent(Object element)
if (element == null)
return null;
return ((MyModel) element).parent;
public boolean hasChildren(Object element)
return ((MyModel) element).child.size() > 0;
public class MyModel
public MyModel parent;
public ArrayList child = new ArrayList();
public int counter;
public MyModel(int counter, MyModel parent)
this.parent = parent;
this.counter = counter;
public String toString()
String rv = "Item ";
if (parent != null)
rv = parent.toString() + ".";
rv += counter;
return rv;
Current Time: Sat May 25 14:56:40 EDT 2013
Powered by FUDForum. Page generated in 0.01562 seconds
