Home » Eclipse Projects » Equinox » how to get rid of old update manager?
how to get rid of old update manager? [message #500918] Mon, 30 November 2009 05:14
Jacek Pospychala is currently offline Jacek Pospychala
I'm getting following issues when first launching a product built with PDE Build:
Bundle "XYZ" version "ABC" has already been installed from: reference:file:plugins/XYZ_ABC.jar
for all bundles in my application. A part of log attached below.
So far I've found following Pascal suggestion:
http://markmail.org/message/kiwoywcqldw2lyaf
He says "This happens when the reconciliation behavior of update.configurator is
not turned off or if you ship update.configurator.
Two ways around this:
1) do not ship update.configurator
2) add to the following propery to the config.ini
org.eclipse.update.reconcile=false"
Now, adding org.eclipse.update.reconcile=false does the job, but it looks like just a workaround. I want to try another solution - but how to not ship "org.eclipse.update.configurator"? It's part of RCP 3.5.0, why wasn't it removed from there?
part of log file:
!ENTRY org.eclipse.update.configurator 4 0 2009-05-30 21:55:12.218
!MESSAGE Could not install bundle plugins/org.eclipse.core.runtime.compatibility_3.2.0.v200710 08.jar Bundle "org.eclipse.core.runtime.compatibility" version "3.2.0.v20071008" has already been installed from: reference:file:plugins/org.eclipse.core.runtime.compatibilit y_3.2.0.v20071008.jar
!MESSAGE Could not install bundle plugins/org.eclipse.core.runtime_3.4.0.v20080512.jar Bundle "org.eclipse.core.runtime" version "3.4.0.v20080512" has already been installed from: reference:file:plugins/org.eclipse.core.runtime_3.4.0.v20080 512.jar
!MESSAGE Could not install bundle plugins/org.eclipse.core.variables_3.2.100.v20080529-1300.ja r Bundle "org.eclipse.core.variables" version "3.2.100.v20080529-1300" has already been installed from: reference:file:plugins/org.eclipse.core.variables_3.2.100.v2 0080529-1300.jar
Previous Topic:Building a standalone Equinox application
Next Topic:Redeploy RAP-Application on WebSphere and JBoss fails
Current Time: Sat May 25 08:18:57 EDT 2013
Powered by FUDForum. Page generated in 0.01423 seconds
