Home » Eclipse Projects » EGit » EGit with HTTP authentication(Is basic http authentication support?)
icon5.gif  EGit with HTTP authentication [message #493852] Wed, 28 October 2009 05:51 Go to next message
Sven-Arne Reinemo is currently offline Sven-Arne Reinemo
I am having trouble cloning a remote repository over HTTP with authentication. I get the following error (names have been changed to protect the innocent):
http://xxx@git.xxx.xxx/xx/xx/model.git/info/refs: cannot read available refs
http://xxx@git.xxx.xxx/xx/xx/model.git/info/refs: 401 Authorization Required
Is this supposed to work in the current version of EGit? I am using EGit from http://www.jgit.org/updates (version 0.5.0.200908282229).
Sven-Arne
Re: EGit with HTTP authentication [message #493949 is a reply to message #493852] Wed, 28 October 2009 11:13 Go to previous messageGo to next message
Shawn O. Pearce is currently offline Shawn O. Pearce
Member
> refs
> Required
It should be working. Apparently, its not, so its a bug.
Re: EGit with HTTP authentication [message #500715 is a reply to message #493949] Fri, 27 November 2009 11:33 Go to previous messageGo to next message
tmarthal  is currently offline tmarthal
To help whomever is assigned this, I am running into the same problem serving up git via http using apache.
Here is my /etc/apache2/conf.d/git.conf
Alias /git /var/git
<Directory "/var/git/">
        Options ExecCGI FollowSymLinks Indexes
        # Deny everyything here
        DAV On
        Deny from all
        AuthType Basic
        AuthName "git repository"
        AuthUserFile /var/git/htpasswd.git
        AuthGroupFile /var/git/htgroup.git
</Directory>
Alias /PROJECT-X.git /var/git/PROJECT-X.git
<Directory "/var/git/PROJECT-X.git/">
        Allow from all
        Order allow,deny
        <Limit GET>
                Require group PROJECT-X-read
        </Limit>
        <Limit GET PUT POST DELETE PROPPATCH MKCOL COPY MOVE LOCK UNLOCK>
                Require group PROJECT-X-write
        </Limit>
</Directory>
Then when I try to Import...Git Repository a new Git installation from within eclipse, I get the initial error. "Cannot lis the available branches. Reason: [url]: cannoe read available refs. 401 Authorization Required". This is by using the url in the import: http://user:password@hostname:80/Project-X.git. All of the fields on the Import Git Repository window form get filled in correctly. I can also do a git clone/push/? all from the command line to the repository.
Has a bug been filed for this? I can file one to get things rolling.
Thanks!
Re: EGit with HTTP authentication [message #500741 is a reply to message #500715] Fri, 27 November 2009 15:46 Go to previous message
Mykola Nikishov is currently offline Mykola Nikishov
Member
tmarthal <marthaler@gmail.com> writes:
Thank you for a detailed description.
Yes, it's exactly this
http://code.google.com/p/egit/issues/detail?id=43 And it was confirmed
for 0.5.0 version by several users.
MAN-UANIC
Re: EGit with HTTP authentication [message #576057 is a reply to message #493949] Fri, 27 November 2009 11:33 Go to previous message
Alias /git /var/git
DAV On
Deny from all
AuthType Basic
</Directory>
Allow from all
Order allow,deny
<Limit GET>
</Limit>
</Limit>
</Directory>
Then when I try to Import...Git Repository a new Git installation from within eclipse, I get the initial error. "Cannot lis the available branches. Reason: [url]: cannoe read available refs. 401 Authorization Required". This is by using the url in the import: http://user:password@hostname:80/Project-X.git All of the fields on the Import Git Repository window form get filled in correctly. I can also do a git clone/push/? all from the command line to the repository.
Thanks!
Re: EGit with HTTP authentication [message #576086 is a reply to message #576057] Fri, 27 November 2009 15:46 Go to previous message
Member
MAN-UANIC
Previous Topic:Create patch with EGit
Next Topic:.gitignore file
Current Time: Tue May 21 06:41:48 EDT 2013
Powered by FUDForum. Page generated in 0.02222 seconds
