Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » I had done as Generate an exetuable test & Run a test, but still getting error as attachment(Quick access TPTP ex. tutorial for novice)
I had done as Generate an exetuable test & Run a test, but still getting error as attachment [message #500654] Fri, 27 November 2009 05:44 Go to next message
Eudona  is currently offline Eudona
Hi Paul:
I had done as Help > Eclipse SDK: Generate an exetuable test & Running a test, but all getting error as attachment.
Please guide where can I get the Quick access TPTP ex. tutorial for novice in order to applying TPTP's URL recording test.
I did as Help, it only open Microsoft Internet Explorer and the recording is completed. I had no chance to input the URL which should be under test.
Thank you very much!
Re: I had done as Generate an exetuable test & Run a test, but still getting error as attachment [message #500657 is a reply to message #500654] Fri, 27 November 2009 06:18 Go to previous message
Paul Slauenwhite is currently offline Paul Slauenwhite
Hi Eudona,
Unfortunately, there is no tutorial. The best source of information is
the product documentation. What errors are you seeing?
Paul
"Eudona" <Eudona.Hwang@msa.hinet.net> wrote in message
news:heoakl$mss$1@build.eclipse.org...
> Hi Paul:
> novice in order to applying TPTP's URL recording test. I did as Help, it
Previous Topic:Does not Eclipst TPTP support playback testing outside Eclipse?
Next Topic:Extending org.eclipse.tptp.platform.models plugin
Current Time: Sun May 19 18:31:57 EDT 2013
Powered by FUDForum. Page generated in 0.01558 seconds
