| How to validate a reference of a porttype in another wsdl file [message #499784] |
Tue, 24 November 2009 01:14  |
grid.qian Messages: 47 Registered: July 2009 |
Member |
Hi all,
I have added a extension for org.eclipse.wst.wsdl.validation.wsdl11validator extend point to validate a bpel partnerlink type in wsdl file.
For now I can validate the error if the reference porttype of partnerlinktype is different from the porttype in a same wsdl file, for example, a.wsdl.
But when the partnerlink type is in another wsdl file, b.wsdl.
b.wsdl import a.wsdl. I can not validate it because the porttype is not in the b.wsdl. I know I can resolve the import element to load the a.wsdl to validate it.
But I want to know if there is a way to do it easier? or can I call some methods to do this?
Grid
| Re: How to validate a reference of a porttype in another wsdl file [message #500002 is a reply to message #499784] |
Tue, 24 November 2009 11:46   |
Valentin Messages: 36 Registered: July 2009 |
Member |
Grid,
When your validator gets called, the list parameter of
org.eclipse.wst.wsdl.validation.internal.wsdl11.soap.SOAPVal idator.validate(Object,
List, IWSDL11ValidationInfo) contains a list with all the parents of the
WSDL element being validated. In that list you should find the parent
Definition object and from that you should be able to get the Import objects
pointing to already loaded imported Definition objects. You can thus find
all the imported objects you're interested in (port types). In JWSDL
1.1/WSDL4J 1.5 there is no one method on the Definition object to compute
this list for you; such a method getAllPortTypes() is only available in
JWSDL 1.2/WSDL4J 1.6, but WTP has not yet adopted this and there are no
plans to do so in the near future.
Hope this helps, Valentin
"grid.qian" <grid.qian@gmail.com> wrote in message
news:heftkl$7fu$1@build.eclipse.org...
> Hi all,
> bpel partnerlink type in wsdl file. For now I can validate the error if
> But when the partnerlink type is in another wsdl file, b.wsdl. b.wsdl
> validate it. But I want to know if there is a way to do it easier? or can
> Thanks
> Grid
FUDForum. Page generated in 0.01654 seconds
