Home » Eclipse Projects » Web Tools Project (WTP) » Bug with links containing "&"?
icon5.gif  Bug with links containing "&"? [message #500056] Tue, 24 November 2009 14:47 Go to next message
Karsten Wutzke is currently offline Karsten Wutzke
when editing HTML files, I have href links like
href="http://books.google.com/books?id=tIQ4CqmJ9e0C&amp ;pg=PA75&lpg=PA75&dq=sql+%22multiple+inherit ance%22&source=bl&ots=IFRtMaansm&sig =7YbSvCHDUjsAX_InmLki1wmwVrs&hl=de&ei=_QnWSt iiGs7-_Aaiq4jZAg&sa=X&oi=book_result&amp ;ct=result&resnum=10&ved=0CDIQ6AEwCQ#v=onepa ge&q=sql%20%22multiple20inheritance%22&f=fal se "
As you can see they contain many "&" 's (to get past the XHTML validator). However, when Ctrl-clicking the links from the web editor, the google books page isn't shown, just some fallback page to the book in general.
This seems to happen because the "&"s aren't decoded. I can see the "&"s in my URL line in the browser (Firefox 3). When clicking the link inside a browser, the link is OK, because it gets decoded.
Is this a bug? Does it already exist?
Karsten
Re: Bug with links containing "&"? [message #500087 is a reply to message #500056] Tue, 24 November 2009 16:47 Go to previous messageGo to next message
Nick Sandonato is currently offline Nick Sandonato
I do not think the problem is with the & separators in your URI, but instead with the # found in the value for parameter ved. In particular, # is used as a delimiter for fragment identifiers as stated in the URI RFC [1]. If needed, you can work around this by changing # to %23.
I think our hyperlink detector might be able to do a better job at making sure that it's not trying to send you to a location based on a URI fragment. So please feel free to open a bug.
[1]. http://www.ietf.org/rfc/rfc2396.txt
Re: Bug with links containing "&"? [message #500103 is a reply to message #500087] Tue, 24 November 2009 18:51 Go to previous messageGo to next message
Hmmm I don't think the # is the problem: when you replace all
with
in Eclipse and Ctrl-click the link, it works perfectly.
Eclipse just doesn't seem do decode the "&" to just "&" before passing it to the external browser. (I also tested the internal browser, they are equal.)
Karsten
Re: Bug with links containing "&"? [message #501073 is a reply to message #500056] Mon, 30 November 2009 16:57 Go to previous messageGo to next message
David Carver is currently offline David Carver
I believe this is a bug, it should be decoding those URL's so they are valid. Please open a bug if it's a duplicate somebody will mark it as such.
Re: Bug with links containing "&"? [message #501105 is a reply to message #501073] Mon, 30 November 2009 23:36 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> such.
I've always encoded & as "&" in our New and Noteworthy pages
where the link represents a Bugzilla query. Looking at the
in-browser source for
http://www.eclipse.org/webtools/releases/3.1.0/newandnotewor thy/index.php,
the & are encoded there and the link works fine. And I routinely
test those queries by activating the link directly within the XML
Editor, where it also works fine.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Bug with links containing "&"? [message #501289 is a reply to message #501105] Tue, 01 December 2009 13:31 Go to previous message
It looks like Karsten opened a bug already https://bugs.eclipse.org/bugs/show_bug.cgi?id=296069
Nitin, I don't think you'll see this problem in the XML editor because I think it's the Anchor hyperlink detector causing the problem since it specifically looks for references with # in them to try and locate an id/name in a file with the fragment after the #.
Previous Topic:Sometimes web project fails to compile - missing tomcat runtime libraries
Next Topic:Embedding XMLEditor in multipageditor
Current Time: Wed May 22 09:08:23 EDT 2013
Powered by FUDForum. Page generated in 0.02386 seconds
