Home » Eclipse Projects » Eclipse Platform » Programmatically add tabs to a TabbedPropertySheet
Programmatically add tabs to a TabbedPropertySheet [message #499047] Thu, 19 November 2009 11:16 Go to next message
fir0 is currently offline fir0
is there any way to programmatically add tabs to a TabbedPropertySheet?
I have a Object which can contain 0 to n childs. All childs are the same type. I already wrote a PropertySection and as long there is 0 or 1 child its working fine. If there are more then 1 child i want to create a tab for each child programmatically (by stil using the same Property Section and Filter). For that i need to know how i can access the "org.eclipse.ui.views.properties.tabbed" extension points in a programmatically and dynamic way.
Can anyone help me?
Best regards
Robert
Re: Programmatically add tabs to a TabbedPropertySheet [message #499111 is a reply to message #499047] Thu, 19 November 2009 16:48 Go to previous messageGo to next message
Aurelien Pupier is currently offline Aurelien Pupier
fir0 wrote on Thu, 19 November 2009 11:16
Is it what you're searching for?
Platform.getExtensionRegistry()
Aurelien Pupier
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
Re: Programmatically add tabs to a TabbedPropertySheet [message #499234 is a reply to message #499111] Fri, 20 November 2009 09:23 Go to previous messageGo to next message
Thank you.
Found http://publib.boulder.ibm.com/infocenter/ledoc/v6r1/index.js p?topic=/com.ibm.rcp.tools.doc.appdev/ttoolbadddynamic.html which helps me to dynamicly create tabs. I really don't like to create contributions by xml but there seems to be no other way Sad
regards,
Robert
Re: Programmatically add tabs to a TabbedPropertySheet [message #499874 is a reply to message #499047] Tue, 24 November 2009 07:55 Go to previous message
After creating Property Tabs dynamically, i also needed to use generic filters. I did not found much about this problem but i dicovered a solution which works for me:
Let the Filter implement IExecutableExtension so you can config the filter by using "<filterclass>:<configurationinformation>" in the filter attribute of a propertySection.
Maybe this sometimes helps someone who got a similar problem.
Robert
Previous Topic:How to enable status line in a tabbed property sheet?
Next Topic:StyledText-AbstractDecoratedTextEditor
Current Time: Wed May 22 22:40:14 EDT 2013
Powered by FUDForum. Page generated in 0.01712 seconds
