| On SLED11, linkActivated() is not called the first time when I clicked on the link [message #499265] |
Fri, 20 November 2009 10:48  |
Florence Messages: 16 Registered: July 2009 |
Junior Member |
I used the IHyperlinkListener class to implement links on a composite. The linkActivated() was called correctly when I did a mouse click on the Windows OS.
However, when I did a mouse click on SLED11, linkActivated() was not called during the first time. I saw the composite got redrawn and re-positioned. The initial mouse down cursor position sort of became the upper right corner
position of the composite once it was anchored.
linkActivated() got called the second time when I clicked on the same link from the anchored composite.
Does anybody see similar issue and know any work around on SLED11?
Thanks.
| Re: On SLED11, linkActivated() is not called the first time when I clicked on the link [message #499632 is a reply to message #499265] |
Mon, 23 November 2009 10:05  |
Grant Gayed Messages: 2128 Registered: July 2009 |
It looks like the forms Hyperlink is just drawing text on a Composite and
then reacting to mouse/key events, so it should work on SLED11 without
problem. There's a runnable snippet in thread
http://www.eclipse.org/forums/index.php?t=msg&th=158060& amp;start=0&S=f6f6fe4444c2cb1eabafc8e6633ea4e0
that includes a Hyperlink; can you try adding a listener to it to see if
it's activated on the first click for you? If it is then your problem must
be somewhate specific to your context, and you'll have to provide a modified
snippet that shows the problem happening.
Grant
"Florence" <florencelu@yahoo.com> wrote in message
news:he6dos$nbk$1@build.eclipse.org...
OS.
upper right corner
> Thanks.
FUDForum. Page generated in 0.01499 seconds
