| Can DTP/ODA be used outside Eclipse [message #499422] |
Sun, 22 November 2009 06:10  |
Joos Buijs Messages: 4 Registered: November 2009 Location: Netherlands |
Junior Member |
Hi all,
I was wondering how much the DTP project depends on Eclipse. Or, in essence, can I use it to connect to data sources in a custom Java application?
And what would I (roughly) need to do if I wanted this? Can I reuse some of the wizards provided with ODA and the ODA drivers etc.?
Thanks in advance!
Joos
| Re: Can DTP/ODA be used outside Eclipse [message #501311 is a reply to message #499422] |
Tue, 01 December 2009 15:10  |
Linda Chan Messages: 840 Registered: July 2009 |
Hi Joos,
The ODA framework uses Eclipse extension points and the OSGi class loading framework to handle the discovery and loading of ODA driver extensions. So all the dependent Eclipse core bundles would need to be included when used in a custom Java appl.
Linda
FUDForum. Page generated in 0.02226 seconds
