Home » Archived » Visual Editor (VE) » VE display trouble
| VE display trouble [message #499240] |
Fri, 20 November 2009 09:29  |
David Kerber Messages: 100 Registered: July 2009 |
I just set up a new machine (Win 7 x64), installed the 64-bit sun jvm
1.6.0_14, Eclipse 3.5.1 and VE 1.4 on it, and now the VE display of the
form/panel/whatever it's called is missing. I get a few faint boxes
outlined on a white background, but no text, and the outline of the form
itself is not there. It seems to run fine, but the visual display is
messed up.
Since it's a visual issue, I have posted a .jpg of a screen capture
here:
http://www.warrenrogersassociates.com/VEDisplay.jpg
If I hover the mouse over that blue "i", it tells me that
'get of the picture failed: "handle"
sShell org.eclipse.swt.widgets.shell'
Any suggestions as to how to fix this?
/~\ The ASCII
\ / Ribbon Campaign
X Against HTML
/ \ Email!
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
| Re: VE display trouble [message #499276 is a reply to message #499240] |
Fri, 20 November 2009 11:31   |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I'm just guessing but it may be due to the 64-bit. The original JNDI
code that captures the picture to display in the VE is 32-bit code.
You can see if this is the problem by setting the JVM for your project
to instead be a 32-bit JVM instead of the default 64-bit jvm and see if
the problem goes away.
> messed up.
> here:
Rich Kulp
| Re: VE display trouble [message #499286 is a reply to message #499276] |
Fri, 20 November 2009 11:42   |
Yves YANG Messages: 686 Registered: July 2009 |
I guess so. I'm using Win7 64 Bits with 32-bit JVM. It works fine.
Best regards
Yves YANG
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:he6g8k$5iu$1@build.eclipse.org...
> I'm just guessing but it may be due to the 64-bit. The original JNDI code
> You can see if this is the problem by setting the JVM for your project to
> instead be a 32-bit JVM instead of the default 64-bit jvm and see if the
> problem goes away.
>> messed up.
>> Since it's a visual issue, I have posted a .jpg of a screen capture here:
>> If I hover the mouse over that blue "i", it tells me that 'get of the
> Rich Kulp
| Re: VE display trouble [message #499312 is a reply to message #499240] |
Fri, 20 November 2009 13:13   |
Originally posted by: mail.mherbst.de
Hi David,
I had the same problem. Then I installed the 32 Bit version of Eclipse
and also a 32 Bit JVM. Now VE works perfectly.
Martin
> messed up.
> here:
| Re: VE display trouble [message #499323 is a reply to message #499276] |
Fri, 20 November 2009 14:16   |
In article <he6g8k$5iu$1@build.eclipse.org>, richkulp@us.NO_SPAM.ibm.com
says...
That did the trick. Of course, I had to install a 32-bit Eclipse, but
then it started working.
Is a fix for this on the VE roadmap? I'd like to go all 64-bit if
possible...
D
> > messed up.
> > here:
/~\ The ASCII
\ / Ribbon Campaign
X Against HTML
/ \ Email!
| Re: VE display trouble [message #499335 is a reply to message #499323] |
Fri, 20 November 2009 16:18   |
I saw tehre are some native codes for 64 bits, including for windows. I
guess it could be a problem eclipse 64 bits with Java 64 bits.
Anyway, we need some contributors to work on the native connection, and to
cupport Cocoa Mac OS as well.
Best regards
Yves YANG
"David Kerber" <ns_dkerber@ns_WarrenRogersAssociates.com> wrote in message
news:MPG.2570b530caf21cba9896ff@news.eclipse.org...
> says...
> possible...
> D
>> > form
>> > messed up.
>> > here:
> /~\ The ASCII
> \ / Ribbon Campaign
> X Against HTML
> / \ Email!
| Re: VE display trouble [message #499336 is a reply to message #499335] |
Fri, 20 November 2009 16:20  |
Sorry, I have clicked on "send" to quick
I saw there are some native codes for 64 bits, including for windows. I
guess it could be a problem of eclipse 64 bits with Java 64 bits.
support Cocoa Mac OS as well.
yves
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:he712r$9tg$1@build.eclipse.org...
> Best regards
> Yves YANG
>> says...
>>> Hi,
>> possible...
>> D
>>> > the
>>> > form
>>> > messed up.
>>> > here:
>> /~\ The ASCII
>> \ / Ribbon Campaign
>> X Against HTML
>> / \ Email!
| Re: VE display trouble [message #617500 is a reply to message #499240] |
> messed up.
> here:
Rich Kulp
| Re: VE display trouble [message #617503 is a reply to message #499276] |
Best regards
Yves YANG
> problem goes away.
>> messed up.
> Rich Kulp
| Re: VE display trouble [message #617509 is a reply to message #499240] |
Hi David,
Martin
> messed up.
> here:
| Re: VE display trouble [message #617512 is a reply to message #499276] |
says...
possible...
D
> > messed up.
> > here:
/~\ The ASCII
\ / Ribbon Campaign
X Against HTML
/ \ Email!
| Re: VE display trouble [message #617514 is a reply to message #499323] |
Best regards
Yves YANG
> says...
> possible...
> D
>> > form
>> > messed up.
>> > here:
> /~\ The ASCII
> \ / Ribbon Campaign
> X Against HTML
> / \ Email!
| Re: VE display trouble [message #617517 is a reply to message #499335] |
yves
> Best regards
> Yves YANG
>> says...
>>> Hi,
>> possible...
>> D
>>> > the
>>> > form
>>> > messed up.
>>> > here:
>> /~\ The ASCII
>> \ / Ribbon Campaign
>> X Against HTML
>> / \ Email!
Current Time: Sat May 18 20:00:42 EDT 2013
Powered by FUDForum. Page generated in 0.02856 seconds
