Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Dialog shell problem
Dialog shell problem [message #499121] Thu, 19 November 2009 18:25 Go to next message
Eclipse User
Originally posted by: guiberger.rediff.com
It appears that on new versions of SWT, the following Dialog shell
seems not working properly on Windows. The outer shell frame is
not appearing etc.
super(p, SWT.ON_TOP | SWT.DIALOG_TRIM | SWT.APPLICATION_MODAL |
SWT.RESIZE);
Suggestions for the options?
Re: Dialog shell problem [message #499639 is a reply to message #499121] Mon, 23 November 2009 10:16 Go to previous message
Grant Gayed is currently offline Grant Gayed
Which versions of swt and Windows are you using? I tried this and I think
it's working as expected.
Grant
"ralf bellinger" <guiberger@rediff.com> wrote in message
news:he4k5m$7n9$1@build.eclipse.org...
> not appearing etc.
> SWT.RESIZE);
Previous Topic:On SLED11, linkActivated() is not called the first time when I clicked on the link
Next Topic:Problem with ScrolledComposite drawing a long list of Labels
Current Time: Fri May 24 20:58:06 EDT 2013
Powered by FUDForum. Page generated in 0.01674 seconds
