Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Problems with import
[Acceleo] Problems with import [message #498950] Thu, 19 November 2009 05:14 Go to next message
Eclipse User
Originally posted by: ilari.heikkinen.helsinki.fi
I've been using Acceleo for roughly two weeks now and I've faced some
issues with the current version (0.9.0M3) import mechanism. Here's a
snippet from my project structure:
Application.mtl:
[module Application('http://myproject/ns/application')/]
[import DomainClass /]
[import Controller /]
[import View /]
[template public generateApplication(g : Application)]
[comment @main /]
[for (e : DomainClass | g.entities )]
[e.generate(g.packageName)/]
[/for]
[for (c : Controller | g.controllers )]
[c.generate(g.packageName)/]
[/for]
[for (v : View | g.views)]
[v.generate()/]
[/for]
[/template]
Controller.mtl:
[module Controller('http://myproject/ns/application')/]
[import Common /]
[template public generate(c : Controller, p : String)]
[/template]
The problem is that when I edit for example Controller and compile
(automatically), the routines are not resolved but marked as errors in
the editor. Now I have to do a clean for the project, "touch" the file
and compile the project again (via save). Errors are now disappeared but
are now existent in other files using the same Common library. I have to
do clean/touch/build -cycles for those modules also. Finally when all
modules using the Common library are clean of errors, the main
Application module cannot resolve the imported Domain/Controller/View
modules so I have to do a clean/touch/build -cycle for the main module also.
I'm using Eclipse 3.4.2 with EMF 2.4.2 and OCL 1.3. Running Eclipse on
Linux.
Do you guys see any error on my project structure or have ideas what
might cause these problems?
Ilari
Ilari Heikkinen
ilari.heikkinen@helsinki.fi
Re: [Acceleo] Problems with import [message #498993 is a reply to message #498950] Thu, 19 November 2009 08:30 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
--------------060606090301090100040508
Hi Ilari,
We've observed and fixed a problem of the sort in the beginning of the
year, and never faced it again whatever the build we tested and whatever
the templates this build was tested on.
Could you raise a bugzilla describing the issue with your templates
attached so that we can try and fix the problem?
Laurent Goubet
Obeo
Ilari Heikkinen wrote:
> Application.mtl:
> [import View /]
> [comment @main /]
> [/for]
> [/for]
> [v.generate()/]
> [/for]
> [/template]
> Controller.mtl:
> [import Common /]
> [/template]
> also.
> Linux.
> Ilari
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------060606090301090100040508--
Re: [Acceleo] Problems with import [message #499025 is a reply to message #498993] Thu, 19 November 2009 09:57 Go to previous messageGo to next message
Eclipse User
filed a new bugzilla entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295598
I want to emphasize that this happens specifically on Linux platform and
I recall not seeing this on Windows (unconfirmed though).
Ilari
On 19/11/09 15:30, Laurent Goubet wrote:
> Hi Ilari,
> Laurent Goubet
> Obeo
>> Application.mtl:
>> [import View /]
>> [comment @main /]
>> [/for]
>> [/for]
>> [v.generate()/]
>> [/for]
>> [/template]
>> Controller.mtl:
>> [import Common /]
>> [/template]
>> but are now existent in other files using the same Common library. I
>> have to do clean/touch/build -cycles for those modules also. Finally
>> when all modules using the Common library are clean of errors, the
>> main Application module cannot resolve the imported
>> Domain/Controller/View modules so I have to do a clean/touch/build
>> Linux.
>> Thanks,
>> Ilari
Re: [Acceleo] Problems with import [message #499032 is a reply to message #499025] Thu, 19 November 2009 10:36 Go to previous message
--------------040107070601050301020003
Ilari,
I use Acceleo on Linux myself and haven't observed this bug since the
beginning of 2009. Thanks for the bug, we'll try and reproduce this on
the latests builds.
Laurent Goubet
Obeo
> Best regards,
> Ilari
>> Hi Ilari,
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> Application.mtl:
>>> [import View /]
>>> [comment @main /]
>>> [/for]
>>> [/for]
>>> [v.generate()/]
>>> [/for]
>>> [/template]
>>> Controller.mtl:
>>> [import Common /]
>>> [/template]
>>> Linux.
>>> Thanks,
>>> Ilari
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------040107070601050301020003--
Previous Topic:[acceleo]Access to java code and properties from scripts
Next Topic:[XPAND/MWE] MetamodelContributor oAW4 -> oAW5
Current Time: Sat May 25 01:31:45 EDT 2013
Powered by FUDForum. Page generated in 0.01787 seconds
