Home » Eclipse Projects » EclipseLink » @ReturnInsert(returnOnly=true) not working with PostgreSQL
@ReturnInsert(returnOnly=true) not working with PostgreSQL [message #496523] Tue, 10 November 2009 07:36 Go to next message
habakuk  is currently offline habakuk
Member
I tried to use the @returnInsert annotation
protected Timestamp insertdate;
and got this exception:
Exception [EclipseLink-193] (Eclipse Persistence Services - 1.2.0.v20091016-r5565): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: There is no custom [InsertObjectQuery] set, but ReturningPolicy contains field(s) to be returned and [PostgreSQLPlatform] doesnt support generating call with returning.
Descriptor: RelationalDescriptor(ppd.model.entities.DVHist --> [DatabaseTable(DV_HIST)])
	at org.eclipse.persistence.exceptions.DescriptorException.noCustomQueryForReturningPolicy(DescriptorException.java:1855)
	at org.eclipse.persistence.descriptors.ReturningPolicy.validationAfterDescriptorInitialization(ReturningPolicy.java:871)
	at org.eclipse.persistence.descriptors.ClassDescriptor.selfValidationAfterInitialization(ClassDescriptor.java:3498)
	at org.eclipse.persistence.descriptors.ClassDescriptor.validateAfterInitialization(ClassDescriptor.java:5222)
	at org.eclipse.persistence.descriptors.ClassDescriptor.postInitialize(ClassDescriptor.java:3218)
I'd like to know how I can make this work with PostgreSQL
Habakuk
Re: @ReturnInsert(returnOnly=true) not working with PostgreSQL [message #497138 is a reply to message #496523] Thu, 12 November 2009 10:35 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
Returning using the "RETURNING" clause is currently only supported on Oracle. For other database native SQL is required for the INSERT/UPDATE to allow returning.
PostgreSQL does seem to have support for the "RETURNING" clause though, so please log a bug to have this support added.
You can customize your own subclass of the PostgreSQLPlatform yourself to add returning support. You need to override the methods, buildCallWithReturning and canBuildCallWithReturning.
I will looking into adding this support in the 2.0 stream.
James : Wiki : Book : Blog
Re: @ReturnInsert(returnOnly=true) not working with PostgreSQL [message #498357 is a reply to message #497138] Mon, 16 November 2009 10:13 Go to previous message
Member
Done (Bug 295259)
Thanks James!
Previous Topic:case insensitive "order by"
Next Topic:proper Maven config?
Current Time: Wed May 22 14:01:13 EDT 2013
Powered by FUDForum. Page generated in 0.02311 seconds
