Home » Eclipse Projects » Rich Client Platform (RCP) » RCP Stop execution of Runnable
RCP Stop execution of Runnable [message #498307] Mon, 16 November 2009 07:14 Go to next message
Juan is currently offline Juan
Hi There!
*I have a "Run" button in my RCP app that launchs a task. This task code
is in a RunnableWithProgress so that I could see its progress and stop
it whenever I need.
When user clicks on "Run", then I run that runnable called "RunCode" using:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().run(tru e,
true, RunCode); //I use it because the
progress monitor if not doesn't appear
*the RunCode is:
class RunCode implements IRunnableWithProgress{
run(IProgressMonitor monitor){
monitor.beginTask("launching ...", IProgressMonitor.UNKNOWN)
//here goes the code of the task
taskActions();
monitor.done();
THE PROBLEM IS THAT i need to STOP the execution programmaticaly but I
dont know how to achieve it because the runnable has no methods to stop
it. Some help would make me happy :)
Re: RCP Stop execution of Runnable [message #498319 is a reply to message #498307] Mon, 16 November 2009 08:28 Go to previous messageGo to next message
Heiko Ahlig is currently offline Heiko Ahlig
Member
Inside the runnable you cancel it like this:
public void run(IProgressMonitor monitor) throws
InvocationTargetException, InterruptedException {
monitor.beginTask("do something ..."
,IProgressMonitor.UNKNOWN);
// do something
if(monitor.isCanceled()){
throw new InterruptedException("Runnable was
canceled.");
//do somthing more
monitor.done();
if you want "cancel" it programmaticaly from outside you need only the
monitor which is used inside the Runable.
The monitor has a method monitor.setCanceled(true) and than you can
stop it inside.
Am 16.11.2009 13:14, schrieb Juan Miguel:
> Hi There!
> it whenever I need.
> true, RunCode); //I use it because the progress monitor if not doesn't
> appear
> *the RunCode is:
> taskActions();
> monitor.done();
> Regards
Re: RCP Stop execution of Runnable [message #498349 is a reply to message #498319] Mon, 16 November 2009 08:44 Go to previous message
Ey Heiko! Thanks a lot for your fast answer.
Unfortunately your proposal would not work in my case because I can't
modify the task method (it's other partner code). I simply want to stop
the thread that runs that method, but I dont know how.
The situation is the following:
other_partner_read_only_method(); //<-- problem: I can't throw
InterruptedException here
monitor.done()
//invoked when monitor cancel button is pressed
//HOW IMPLEMENT THIS TO STOP RUNCODE.RUN() ???
public void stopRunCode(){
I want to stop the Runnable from a stopRunCode() method, invoked when
the monitor is monitor.isCancelled equals true-checking that I do from a
thread that continuosly is checking for it)
> @Override
> // do something
> canceled.");
> //do somthing more
> monitor.done();
> stop it inside.
>> Hi There!
>> it whenever I need.
>> using:
>> appear
>> *the RunCode is:
>> taskActions();
>> monitor.done();
>> Regards
Previous Topic:Have to manually start org.eclipse.runtime in product
Next Topic:Splash screen freezes often in application based on Eclipse
Current Time: Sat May 18 15:05:41 EDT 2013
Powered by FUDForum. Page generated in 0.05517 seconds
