Home » Eclipse Projects » DSDP - Target Management » "Browse For Folder" Dialog does not work as expected
| "Browse For Folder" Dialog does not work as expected [message #498312] |
Mon, 16 November 2009 07:49  |
Martin Tauber Messages: 93 Registered: July 2009 |
Member |
Hello everybody,
I'm using the "Browse For Folder" Dialog to browse RSE Filesystems. But
I'm running into some problems:
1.) When I create a new Connection using the dialog, It will only be
shown in the Connection field, when I close the dialog and open it again.
2.) To me it seams, that the "Password" Dialog is not shown properly.
When I try to browse the RSE Filesystem the first time (This is the time
when I would expect to see the Password dialog) The browser hangs. After
pressing "Cancel" I get to see the password dialog, but this is to late.
Any Ideas, what I am doing wrong?
Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #500005 is a reply to message #498854] |
Tue, 24 November 2009 11:54   |
David McKnight Messages: 229 Registered: July 2009 |
Hi Martin,
In your moving forward with this problem, what issues remain?
Dave
"Martin Tauber" <martin.tauber@t-online.de> wrote in message
news:he1ghp$eqe$1@build.eclipse.org...
> Hi Again,
> I moved a little bit forward with my problem. It seams to be that I call
> the browse dialg to early. I am using a wizard which I call from
> postWindowOpen method of the applicatin workbench adviser.
> does that help?
> Regards
> Martin
> Martin Tauber wrote:
>> Hello everybody,
>> Thanks
>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #500549 is a reply to message #500005] |
Thu, 26 November 2009 11:04   |
Member |
Hi David,
first of all many thanks for your help, I really appreciate it.
The Problem still remains. Maybe It's helpfull if I add a little
background information. I am developing an application where users can
edit files on a remote system. During startup of the RCP application in
the method postWindowOpen() I check if a project was created with a link
to a remote filesystem. If not I trigger a wizard where the user can
create a link to the remote system (using
FileSystemContributor.browseFileSystem()). If I create a connection in
this dialog, I will not be able to see the connection in the then
following standard dialog where I can choose a file :-(
Nevertheless if I skip my wizard during startup and then call it after
startup is complete, everything works fine...
Martin
When I use the FileSystemContributor.browseFileSystem() method during
postWindowOpen() I can create a connection, but I don't see the
connection until I reopen my dialog. This only works around my problem
David McKnight wrote:
> Hi Martin,
> Dave
>> Hi Again,
>> does that help?
>> Regards
>> Martin
>>> Hello everybody,
>>> Thanks
>>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #501327 is a reply to message #500549] |
Tue, 01 December 2009 15:31   |
Hi Martin,
When I create a connection from within the "BrowseFor File" dialog (i.e.
from FileSystemContributor.browseFileSystem()), the connection gets added to
the list of connections in the Connection combo box. Are you saying that,
in your case, the new connection you created is not listed there?
Dave
news:hem8vp$akl$1@build.eclipse.org...
> Hi David,
> Regards
> Martin
> postWindowOpen() I can create a connection, but I don't see the connection
>> Hi Martin,
>> Dave
>>> Hi Again,
>>> does that help?
>>> Regards
>>> Martin
>>>> Hello everybody,
>>>> again.
>>>> time when I would expect to see the Password dialog) The browser hangs.
>>>> After pressing "Cancel" I get to see the password dialog, but this is
>>>> to late.
>>>> Thanks
>>>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #501964 is a reply to message #501327] |
Fri, 04 December 2009 10:25   |
Member |
Hi David,
yes, but only if I call the "Browse For File" dialog during startup from
the postWindowOpen() method ...
Keep in mind that I'm developing my own RCP.
The other symptom I have for I guess the same problem is, that if I have
created a link to a rse filesystem and restart my program, it just hangs
forever ...
Martin
> Hi Martin,
> Dave
>> Hi David,
>> Regards
>> Martin
>>> Hi Martin,
>>> Dave
>>>> Hi Again,
>>>> does that help?
>>>> Regards
>>>> Martin
>>>>> Hello everybody,
>>>>> again.
>>>>> to late.
>>>>> Thanks
>>>>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #502011 is a reply to message #501964] |
Fri, 04 December 2009 13:04  |
If the problem is something that occurs during startup, then there are a
number of startup issues to consider. Before the RSE can be used, you need
to be sure that the RSE profile has been initialized properly. If this is
what's happening, one way to ensure that RSE is loaded is to call
RSECorePlugin.waitForInitCompletion() before using the RSE registry.
There are also some known issues with using RSE's EFS provider before
Eclipse has fully initialized (a chicken-and-egg problem). In order to
avoid that, you need to delay accessing RSE EFS resources until Eclipse is
fully loaded.
Hopefully this will help,
Dave
news:hfb9mq$8f0$1@build.eclipse.org...
> Hi David,
> forever ...
> Regards
> Martin
>> Hi Martin,
>> to the list of connections in the Connection combo box. Are you saying
>> that, in your case, the new connection you created is not listed there?
>> Dave
>>> Hi David,
>>> Regards
>>> Martin
>>>> Hi Martin,
>>>> Dave
>>>>> Hi Again,
>>>>> call the browse dialg to early. I am using a wizard which I call from
>>>>> does that help?
>>>>> Regards
>>>>> Martin
>>>>>> Hello everybody,
>>>>>> But I'm running into some problems:
>>>>>> again.
>>>>>> hangs. After pressing "Cancel" I get to see the password dialog, but
>>>>>> this is to late.
>>>>>> Thanks
>>>>>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #582844 is a reply to message #498312] |
Wed, 18 November 2009 14:05  |
Member |
Hi Again,
does that help?
Martin
> Hello everybody,
> Thanks
> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #582867 is a reply to message #498854] |
Hi Martin,
Dave
> Hi Again,
> does that help?
> Regards
> Martin
>> Hello everybody,
>> Thanks
>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #582877 is a reply to message #500005] |
Member |
Hi David,
Martin
> Hi Martin,
> Dave
>> Hi Again,
>> does that help?
>> Regards
>> Martin
>>> Hello everybody,
>>> Thanks
>>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #582893 is a reply to message #500549] |
Hi Martin,
Dave
> Hi David,
> Regards
> Martin
>> Hi Martin,
>> Dave
>>> Hi Again,
>>> does that help?
>>> Regards
>>> Martin
>>>> Hello everybody,
>>>> again.
>>>> to late.
>>>> Thanks
>>>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #582912 is a reply to message #501327] |
Member |
Hi David,
forever ...
Martin
> Hi Martin,
> Dave
>> Hi David,
>> Regards
>> Martin
>>> Hi Martin,
>>> Dave
>>>> Hi Again,
>>>> does that help?
>>>> Regards
>>>> Martin
>>>>> Hello everybody,
>>>>> again.
>>>>> to late.
>>>>> Thanks
>>>>> Martin
| Re: "Browse For Folder" Dialog does not work as expected [message #582924 is a reply to message #501964] |
fully loaded.
Dave
> Hi David,
> forever ...
> Regards
> Martin
>> Hi Martin,
>> Dave
>>> Hi David,
>>> Regards
>>> Martin
>>>> Hi Martin,
>>>> Dave
>>>>> Hi Again,
>>>>> does that help?
>>>>> Regards
>>>>> Martin
>>>>>> Hello everybody,
>>>>>> again.
>>>>>> this is to late.
>>>>>> Thanks
>>>>>> Martin
Current Time: Wed May 22 20:34:47 EDT 2013
Powered by FUDForum. Page generated in 0.05274 seconds
