| Change Editor Tabs background color [message #498272] |
Mon, 16 November 2009 04:55  |
Juan Messages: 29 Registered: July 2009 |
Junior Member |
Hi everybody,
I need to change the default tabs color for the editors in my RCP app.
I nearly achieve it by creating a Theme (org.eclipse.ui.themes
extension) and setting the next color overrides:
-ACTIVE_TAB_BG_START: 255,0,0 (red for example)
-ACTIVE_TAB_BG_END: 255,0,0
-INACTIVE_TAB_BG_START: 0,255,0 (yellow for example)
-INACTIVE_TAB_BG_END: 0,255,0
-ACTIVE_NOFOCUS_TAB_BG_START: 0,0,255 (green for example)
But... What about the default tab color? I need by default all the tabs
have a color and not the default gray that currently have.
Does anybody have an idea about this?
Best Regards.
| Re: Change Editor Tabs background color [message #498840 is a reply to message #498272] |
Wed, 18 November 2009 13:28  |
Wim Jongman Messages: 417 Registered: July 2009 |
Hi Juan,
Is it not defined by either active_tab OR inactive_tab? What do you mean by
default tab?
Wim
> Hi everybody,
> Best Regards.
FUDForum. Page generated in 0.03446 seconds
