Home » Eclipse Projects » Rich Client Platform (RCP) » Errors on preferences page
Errors on preferences page [message #498261] Mon, 16 November 2009 03:56 Go to next message
Eclipse User
Originally posted by: victor.conesa.justinmind.com
Hi all,
there are some issues with the code that handles enabling the Next and
Previous function that the arrow keys generate.
1) on first opening the Preferences dialog,
- the "General" pane title is selected in the tree list, but the selection
shows an inactive (greyed) highlight
- a flashing cursor appears in the filter field
- the orange "Forward" and "Back" widgets at upper right of the dialog are
both disabled (greyed out).
2) pressing the Tab key
- removes the flashing cursor from the filter field
- displays the phrase "type filter text" in grey text in the filter field
- selects the "General" pane title in the list at left, highlighting it
with the system highlight color
- but does *not* visually enable the "Forward" and "Back" buttons
- however, the tree list will respond to Down arrow key presses
3) pressing the Down arrow key once:
- deselects the current pane title in the tree list at left, correctly
un-highlighting it
- selects the next lower pane title in the tree list, highlighting it with
- visually enables the "Back" button at upper right (though this may not
appear until several moves later, if doing rapid repeated Down arrow inputs)
- does not visually enable the "Forward" button
- however, the dialog does respond to Up or Down arrow key presses
- repeating this step moves the selected pane sequentially down the tree
list as expected, but
- the enabled/disabled visual states of the "Back" and "Forward"
buttons do not change
4) on pressing the Up arrow key
- selects the prior (vertically higher) pane title in the list at left,
highlighting it with the system highlight color
- deselects the current pane title in the list at left, correctly
un-highlighting it
- continues showing the "Back" button as enabled
- but does not enable the "Forward" button at upper right
- the dialog responds to Up or Down arrow key presses appropriately
in the meantime, all/any selection movements are apparently being pushed on
a history stack
- this also occurs if one moves around the tree list non-sequentially, by
selecting different titles directly with the mouse
5) if at any time the "Back" button is *clicked*
- the pane selection is moved backward "down" the history stack
- the "Forward" button at upper right is enabled
clicking the "Back" and "Forward" buttons thereafter
- relocates the pane title selection by moving up or down the history
stack
this is extremely confusing behavior!
strongly urge you consider;
- changing the "Back" and "Forward" buttons to move up or down the tree
list, only, in immediate mode (vs. tracking a history stack;)
- illuminating the "Forward" button at all selection locations other than
the lowest tree position
- illuminating the "Back" button at all selection locations other than the
highest tree position
also: I'm not really clear what "Key Scrolling" means in the small widget at
upper right of the Preferences dialog; but I think it allows me to turn off
using the Up and Down arrow keys to navigate the tree list. I don't
understand what usability goal merits such an unusual feature...
Re: Errors on preferences page [message #498845 is a reply to message #498261] Wed, 18 November 2009 13:52 Go to previous message
Wim Jongman is currently offline Wim Jongman
No problem so far.
If the search box does not play in the history function (which it doesn't)
then so far everything is ok.
> un-highlighting it
inputs)
Yes, I see. That could be a design decision. Rapid keymovements are not
triggered by this mechanism (Post Selection Listener), you could argue that
they should be included. I personally would not.
Pressing the up OR down key triggers a NEXT action on the stack. This adds
actions to the BACK stack but not to the forward stack. So okay so far?
> un-highlighting it
Sounds good :-)
> a history stack
> stack
it could be but it is consistent. Are there any UI guidelines stating that
this is wrong?
Also not really clear but clicking it stops key scrolling altogether.
Previous Topic:Change Editor Tabs background color
Next Topic:OSGi service bundle start options - noobie
Current Time: Sun May 19 07:01:25 EDT 2013
Powered by FUDForum. Page generated in 0.02153 seconds
