Home » Eclipse Projects » Rich Client Platform (RCP) » Image position in TableViewer(Image position)
Image position in TableViewer [message #498207] Sun, 15 November 2009 16:34 Go to next message
Franck Lepretre is currently offline Franck Lepretre
I created a Table linked to a model.
There are several images used at different column positions.
The images are always left aligned.
The setAlignment is only for the text.
Is there any other solution for this?
Franck
Re: Image position in TableViewer [message #498212 is a reply to message #498207] Sun, 15 November 2009 17:12 Go to previous messageGo to next message
Wim Jongman is currently offline Wim Jongman
Hi Franck,
I am positive you can find your solution in the Table section of the SWT
snippets page:
http://www.eclipse.org/swt/snippets/
Wim
> Thanks
> Franck
Re: Image position in TableViewer [message #498260 is a reply to message #498212] Mon, 16 November 2009 03:52 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
You need to use ower draw to position the image.
Tom
Wim Jongman schrieb:
> Hi Franck,
> snippets page:
> Best regards,
> Wim
>> Thanks
>> Franck
Re: Image position in TableViewer [message #498431 is a reply to message #498260] Mon, 16 November 2009 16:54 Go to previous message
Thanks for the info.
Yes, I followed Tom's advice and found a good example (made by Tom!) that shows how to proceed :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet051TableCenteredImage.java?view=markup
Thanks again your help.
Franck
[Updated on: Mon, 16 November 2009 17:30]
Report message to a moderator
Previous Topic:Extending a wizard
Next Topic:Eclipse RCP user-friendly forms plugin or library?
Current Time: Mon May 20 11:49:35 EDT 2013
Powered by FUDForum. Page generated in 0.01909 seconds
