Home » Eclipse Projects » Rich Client Platform (RCP) » I dont know how to use the IProgressMonitor stop button :(
I dont know how to use the IProgressMonitor stop button :( [message #497026] Thu, 12 November 2009 05:06 Go to next message
Juan is currently offline Juan
Hi everybody!
I have a IProgressMonitor that I used when I launch a process since my
RCP: monitor.beginTask("Launching planner...",
IProgressMonitor.UNKNOWN);
I need to give users the posibility to stop the process using the stop
button of this progress monitor (it appears by default) but that button
do nothing when pressed and I don't know how to listen when user press
that button.
I've thought to implement an async thread that checks by polling if
monitor.isCanceled() is true, but I think that is not the best way.Does
anybody has an idea about this?
Thanks a lot and the best regards.
Re: I dont know how to use the IProgressMonitor stop button :( [message #497050 is a reply to message #497026] Thu, 12 November 2009 06:33 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Juan,
Generally the code itself that's using the monitor to trace progress
should be checking the flag and terminating quickly...
Juan Miguel wrote:
> Hi everybody!
> button do nothing when pressed and I don't know how to listen when
> user press that button.
> way.Does anybody has an idea about this?
Re: I dont know how to use the IProgressMonitor stop button :( [message #497096 is a reply to message #497050] Thu, 12 November 2009 08:32 Go to previous messageGo to next message
Yes, you're right but I was looking another sort of help, because it's
that checking of the flag what I dont know how to implement.
> Please don't cross post the same question to multiple newsgroups;
this isn't an SWT question.
Yes you're right. But think that the problem is relates to a
org.eclipse.jface.operation.AccumulatingProgressMonitor and I thought
some people expert in SWT perhaps would know something about this.Sorry.
Thanks!
Ed Merks escribió:
> Juan,
> Juan Miguel wrote:
>> Hi everybody!
Re: I dont know how to use the IProgressMonitor stop button :( [message #498101 is a reply to message #497026] Sat, 14 November 2009 08:30 Go to previous message
Wim Jongman is currently offline Wim Jongman
Hi Juan,
The pattern is like this (ignore the bad !style).
mon.
doWork(IProgressMonitor mon){
boolean workComplete = false;
while(!mon.isCancelled() && !workComplete){
workComplete = a_little_work(); }
if(!workComplete && mon.isCancelled){
dialog("You pressed the cancel button before work was complete")
Now, the good behaviour is to check the cancel button frequently.
Wim
> Hi everybody!
> that button.
Previous Topic:Registring a new Action outside the ApplicationActionBarAdvisor
Next Topic:How to set the editor title?
Current Time: Tue May 21 12:22:32 EDT 2013
Powered by FUDForum. Page generated in 0.01879 seconds
