Home » Newcomers » Newcomers » Lua DLL(How to insert a LUA dll and use that for running and debugging)
Lua DLL [message #497683] Fri, 13 November 2009 05:46 Go to next message
No real name is currently offline No real name
I have a simulator that uses a LUA DLL and I run tests on that. Now I want to use eclipse to compile my test code also written in LUA. And run and debug everything. So I want to be able to debug my test code and the code inside the DLL.
Can anybody help me by telling me how I can configure Eclipse so the lua code can be used. I have no Lua interpreter or compiler. I want to use the dll in stead. Is this possible?
Hope someone can help me.
I have Eclipse version 3.5.1 installed and the Lua plugin luaEclipse version 1.2
Re: Lua DLL [message #498008 is a reply to message #497683] Fri, 13 November 2009 11:49 Go to previous message
Chris Aniszczyk is currently offline Chris Aniszczyk
roland.rolandkramer@gmail.com wrote:
> Hi
> version 1.2
I would ask this question on the CDT newsgroups.
I'm forwarding the question there.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Previous Topic:Can't Turn Off Folding
Next Topic:Why am I getting compile errors when library is in the classpath?
Current Time: Sat May 25 19:53:46 EDT 2013
Powered by FUDForum. Page generated in 0.07317 seconds
