Home » Eclipse Projects » Rich Client Platform (RCP) » Binding a set of radio buttons to an int property
Binding a set of radio buttons to an int property [message #497090] Thu, 12 November 2009 08:50 Go to next message
Damien is currently offline Damien
Hello everybody,
I am trying to bind a set of radio buttons to an int property. Is there a short way of doing that? Every solution I have found on the Web was quite long.
Damien
Re: Binding a set of radio buttons to an int property [message #497146 is a reply to message #497090] Thu, 12 November 2009 11:03 Go to previous messageGo to next message
Matthew Hall is currently offline Matthew Hall
Damien wrote:
> Hello everybody,
> quite long.
> Damien
RadioGroup is a good fit for this, although I have not written any
databinding properties for that widget yet. If you will file a bugzilla
I can get that done within a day or two.
Otherwise you can use SelectObservableValue:
SelectObservableValue select = new SelectObservableValue(int.class);
IValueProperty selectionProp = WidgetProperties.selection();
for (int i = 0; i < buttons.length; i++)
select.addOption(
Integer.valueOf(i),
selectionProp.observe(buttons[i]) );
bindingContext.bind(
select,
BeanProperties.value("myProperty").observe(myModel) );
Matthew
Re: Binding a set of radio buttons to an int property [message #497155 is a reply to message #497146] Thu, 12 November 2009 12:24 Go to previous message
Thanks a lot Matthew, SelectObservableValue was exactly what I was looking for (I am new to databindings). It works perfectly.
Damien
Previous Topic:Byte Order Mark ( BOM ) and Editor
Next Topic:Resource doesn't exist
Current Time: Sat May 25 21:05:08 EDT 2013
Powered by FUDForum. Page generated in 0.01482 seconds
