Home » Eclipse Projects » Rich Client Platform (RCP) » rcp application and editor ...
rcp application and editor ... [message #497073] Thu, 12 November 2009 08:02 Go to next message
Carmelo  is currently offline Carmelo
Hi all,
I have an rcp application that use the ide open editor to edit external file
if I have dirty editor I will get the right message asking to save before
the application closes ...
what I don't wont is to find the editor opened again when the application is
restarted ...
where do I need to add the listener to check if there are still opened
editors before everything gets closed...
I have tried in the stop (Activator - abstractui plugin) with no result ...
probably I should play somewhere in the Application ... but I guess it will
be to late there to get some available page and from there list the editors
and close it ...
so what I would love is to be able to close the application and reopened it
again with NO EDITOR opened ...
thanks
Kar
Re: rcp application and editor ... [message #497097 is a reply to message #497073] Thu, 12 November 2009 08:39 Go to previous messageGo to next message
Eclipse User
Originally posted by: wangqs_eclipse.yahoo.com
In your WorkbenchAdvisor::initialize method, call
configurer.setSaveAndRestore(false). This will disable the workbench
saving the state when existing.
Q.S.
Kar wrote:
> Hi all,
> file ...
> before the application closes ...
> application is restarted ...
> ... probably I should play somewhere in the Application ... but I guess
> it will be to late there to get some available page and from there list
> the editors and close it ...
> it again with NO EDITOR opened ...
> thanks
> Kar
Re: rcp application and editor ... [message #497844 is a reply to message #497097] Fri, 13 November 2009 08:18 Go to previous messageGo to next message
Hi Wang,
I know that ... but this means that even all the rearranged views will be
dismissed and I don't want this :(
any idea
"Wang Q.S" <wangqs_eclipse@yahoo.com> wrote in message
news:hdh35u$j42$1@build.eclipse.org...
> Q.S.
> Kar wrote:
>> Hi all,
>> file ...
>> is restarted ...
>> thanks
>> Kar
Re: rcp application and editor ... [message #498082 is a reply to message #497844] Sat, 14 November 2009 06:29 Go to previous messageGo to next message
Wim Jongman is currently offline Wim Jongman
Hi Q.S.,
In one of the windowadvisor classes savestate method you can close all the
editors.
getWindowConfigurer().getWindow().getActivePage().getEditorR eferences();
You might want to run over all pages and not just the active page...
Wim
> Hi Wang,
> any idea
>> Q.S.
>> Kar wrote:
>>> Hi all,
>>> file ...
>>> is restarted ...
>>> thanks
>>> Kar
Re: rcp application and editor ... [message #498237 is a reply to message #497844] Sun, 15 November 2009 23:13 Go to previous messageGo to next message
Eclipse User
Kar wrote:
> Hi Wang,
> be dismissed and I don't want this :(
> any idea
>> Q.S.
>> Kar wrote:
>>> Hi all,
>>> external file ...
>>> opened editors before everything gets closed...
>>> result ... probably I should play somewhere in the Application ...
>>> but I guess it will be to late there to get some available page and
>>> from there list the editors and close it ...
>>> reopened it again with NO EDITOR opened ...
>>> thanks
>>> Kar
You can try to open all the editor as Wim said in his message.
Or you can access the memento directly
IPath path = WorkbenchPlugin.getDefault().getDataLocation();
path = path.append("workbench.xml");
File stateFile = path.toFile();
FileInputStream input = new FileInputStream(stateFile);
BufferedReader reader = new BufferedReader(
new InputStreamReader(input, "utf-8")); //$NON-NLS-1$
IMemento memento = XMLMemento.createReadRoot(reader);
and delete all editor references under tag IWorkbenchConstants.TAG_EDITOR
Q.S Wang
http://www.myeclipsedev.com/
Re: rcp application and editor ... [message #498330 is a reply to message #498237] Mon, 16 November 2009 09:01 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Eclipse User wrote on Sun, 15 November 2009 23:13
Q.S Wang
Here be dragons. Just a note that this is not guaranteed to be the same even between maintenance releases (3.5.0 to 3.5.1 for example). This is considered hacking the internals.
PW
Re: rcp application and editor ... [message #498332 is a reply to message #498082] Mon, 16 November 2009 09:05 Go to previous messageGo to next message
Wim Jongman wrote on Sat, 14 November 2009 06:29
Hi Q.S.,
editors.
What Wim suggests is probably your best bet.
I would try in the WorkbenchWindowAdvisor preClose methods, and if they aren't complete enough then try org.eclipse.ui.application.WorkbenchAdvisor.preShutdown()
If your RCP app only has one window, then you just have to walk one window/one active page.
PW
Re: rcp application and editor ... [message #498564 is a reply to message #498330] Tue, 17 November 2009 09:28 Go to previous messageGo to next message
sorry for the delay in answering and thank u all for the replays ...
BUT STILL I HAVE THE PROBLEM :-(
so the only place where the test works fine is inside the preShutdown ...
but
let's say u have a few editors opened and dirty ... the preShutdown will be
called before the save dialog will be displayed so I have to force to discar
or save without even asking the user ...
same thing if I the closing editors will be performed inside the
preWindowShellClose
the only place where I will get the dialog correctly displayed (so that I
can save or discard changes) is inside the saveState ... I can close the
editors correctly ...
but I guess the memento have already been written and when I restart the rcp
application I will get the editors opened again :-(
what can I try ???
in the meantime I will see if I can access the memento and modify it
manually
Thanks all of u
Kar
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:hdrlvi$4hr$1@build.eclipse.org...
>> Q.S Wang
> PW
> Paul Webster
> http://wiki.eclipse.org/Platform_Command_Framework
> http://wiki.eclipse.org/Command_Core_Expressions
> http://wiki.eclipse.org/Menu_Contributions
Re: rcp application and editor ... [message #498665 is a reply to message #498564] Tue, 17 November 2009 18:25 Go to previous messageGo to next message
Eclipse User
> ... but
> be called before the save dialog will be displayed so I have to force to
> discar or save without even asking the user ...
> preWindowShellClose
> I can save or discard changes) is inside the saveState ... I can close
> the editors correctly ...
> rcp application I will get the editors opened again :-(
> what can I try ???
> manually
> Thanks all of u
> Kar
>>> Q.S Wang
>> PW
>> Paul Webster
After the memento have been saved, you can access the memento file and
delete the whole editor node. You don't need do it at the closing stage
if you can't find the right place, but do it in pre-startup or wherever
fit to your requirements. The deleting just need be done before the
workbench tried to restore the editors.
But remember as what Paul said, assessing the memento file is kinds of
hacking way.
Q.S. Wang
Re: rcp application and editor ... [message #498696 is a reply to message #498665] Wed, 18 November 2009 03:36 Go to previous message
I did check yesterday a bit better and the saveState is actually empty when
I start closing the editors ... probably the editor registry doesn't get
correctly updated when the shutdown process as already started ... and
that's why even if I close them they will be reopened afterwards.
so I guess I will clean up the memento on the startup phase avoiding even to
close the editors as they will be closed anyway during the editor dispose.
I know that this will probably change with new releases but for now I guess
this is the only solution I have got left.
thanks u all guys
Ciao
Carmelo
news:hdvbce$ii2$1@build.eclipse.org...
>> but
>> preWindowShellClose
>> what can I try ???
>> manually
>> Thanks all of u
>> Kar
>>>> Q.S Wang
>>> PW
>>> Paul Webster
> delete the whole editor node. You don't need do it at the closing stage if
> you can't find the right place, but do it in pre-startup or wherever fit
> to your requirements. The deleting just need be done before the workbench
> hacking way.
> Q.S. Wang
Previous Topic:Get LabelProvider from active View
Next Topic:DateTime control in CellEditor Example
Current Time: Tue Jun 18 00:54:09 EDT 2013
Powered by FUDForum. Page generated in 0.02186 seconds
