Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Re: Error trying to partially p2.mirror EMF 2.5.0 update site
| [buckminster-dev] Re: Error trying to partially p2.mirror EMF 2.5.0 update site [message #496909] |
Wed, 11 November 2009 11:45 |
Nick Boldt Messages: 480 Registered: July 2009 |
The issue here is that the metadata is incomplete, and p2 (p2.director,
anyway - haven't tried w/ p2.mirror) only knows how to find foo.jar as
foo.jar.pack.gz in a jar:file:/path/to/repo.zip!/. If you omit the
jar:file: prefix or !/ suffix, or point at http://path/to/repo.zip, or
even unpack the zip as file:/path/to/repo.zip_, p2 can't find the packed
plugin jars.
(I've complained about this limitation but there's been no buy-in from
the p2 devs so far that this ought to be fixed, mostly I suspect because
there is a simple workaround and by fixing it they're encouraging
"broken" repos to be produced. Ours is "broken" because it saves disk
space and bandwidth; if we skip the packing step or include BOTH the
packed and unpacked jars in the zip, the file gets much larger.)
That said, I've been able to successfully mirror from a "broken" repo
zip like the EMF one using the Buckminster Aggregator.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=294832 for a quick way
to get a director app, then use that to install Buckminster, and from
there be able to do selective mirroring and even recategorization or
features. There's also a Buckminster Aggregator Editor which lest you
set up what to mirror graphically. Very cool, IMHO.
http://wiki.eclipse.org/Getting_Started_With_Aggregator_(Buckminster)
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.dash/at hena/org.eclipse.dash.commonbuilder/org.eclipse.dash.common. releng/tools/scripts/aggregateRepos.xml?root=Technology_Proj ect&view=markup
Nick
Ed Merks wrote:
> Mark,
> I'm not sure what this means. Maybe it's better to ask on the p2
> newsgroup or mailing list, or maybe someone else more knowledgeable will
> help.
> Mark Melvin wrote:
>> I am trying to partially mirror the EMF 2.5.0 P2 repository that I
>> downloaded and I am getting an error. This could be a P2 thing, but I
>> am wondering if someone could point me in the right direction. Here
>> is my Ant call:
>> <p2.mirror verbose="true" ignoreErrors="true">
>> <repository location="file:${final.p2.repo.dir}" compressed="true"
>> name="EMF repository" />
>> <source dir="${repoBaseLocation}/"
>> includes="emf-xsd-Update-2.5*.zip"/>
>> <iu id="org.eclipse.xsd.feature.group" />
>> <iu id="org.eclipse.emf.ecore.feature.group" />
>> <iu id="org.eclipse.emf.common.feature.group"/>
>> </p2.mirror>
>> I get the following output:
>> [java] [p2.mirror] Problems resolving provisioning plan.
>> [java] [p2.mirror] Unable to satisfy dependency from
>> org.eclipse.emf.common.feature.group 2.5.0.v200906151043 to
>> org.eclipse.core.runtime 0.0.0.
>> org.eclipse.xsd.feature.group 2.5.0.v200906151043 to
>> org.eclipse.emf.ecore.feature.group 2.5.0.v200906151043 to
>> org.eclipse.emf.common 2.5.0.v200906151043 to bundle
>> org.eclipse.core.runtime [3.5.0,4.0.0].
>> org.eclipse.emf.ecore 2.5.0.v200906151043 to bundle
>> org.eclipse.xsd 2.5.0.v200906151043 to bundle org.eclipse.core.runtime
>> [3.5.0,4.0.0].
>> org.eclipse.emf.ecore.change 2.5.0.v200906151043 to bundle
>> org.eclipse.emf.ecore.xmi 2.5.0.v200906151043 to bundle
>> [java] [p2.mirror] Mirroring:
>> osgi.bundle,org.eclipse.emf.ecore,2.5.0.v200906151043 (Descriptor:
>> canonical: osgi.bundle,org.eclipse.emf.ecore,2.5.0.v200906151043)
>> packed: osgi.bundle,org.eclipse.emf.ecore,2.5.0.v200906151043)
>> [java] [p2.mirror] Messages while mirroring artifact descriptors.
>> [java] [p2.mirror] Artifact not found:
>> osgi.bundle,org.eclipse.emf.ecore,2.5.0.v200906151043.
>> [java] [p2.mirror]
>> jar:file:/c:/Temp/emf-xsd-Update-2.5.0.zip!/plugins/org.ecli
>> pse.emf.ecore_2.5.0.v200906151043.jar
>> [java]
>> [java] BUILD FAILED
>> [java] C:\Temp\emf_only.xml:39: Messages while mirroring artifact
>> descriptors.
>> [java] Artifact not found:
>> osgi.bundle,org.eclipse.emf.ecore,2.5.0.v200906151043.Messag es while
>> [java]
>> [java] Total time: 0 seconds
>> Ignoring unsatisfied dependencies to org.eclipse.core.runtime, it is
>> failing to find org.eclipse.emf.ecore_2.5.0.v200906151043.jar in the
>> zip file. I see it is there, but it is a .jar.pack.gz file. Do I
>> need to do anything special for P2 to be able to deal with this, or is
>> there a problem with the P2 repository provided on the website?
>> Any help would be appreciated.
>> Thanks,
>> Mark.
Nick Boldt :: http://nick.divbyzero.com
Current Time: Wed May 22 02:12:27 EDT 2013
Powered by FUDForum. Page generated in 0.01481 seconds
