Home » Modeling » GMT (Generative Modeling Technologies) » [Episilon] Eugenia: Graphical Containment to represent Model Containment
[Episilon] Eugenia: Graphical Containment to represent Model Containment [message #496608] Tue, 10 November 2009 11:44 Go to next message
Maurice O'Connor is currently offline Maurice O'Connor
Member
I notice when I use Eugenia with the Filesystem example, Folder extends File is treated as a container in the generated diagram editor.
However, I would like to populate:
val File[*] contents;
Via a container on the diagram editor. So the user puts a Folder Node on the canvas (where it appears as a container), then populates contents by adding File Nodes within this Folder.
Is this possible? If so, can anyone hint as to the correct annotation for this?
Hopefully this is clear, thanks!
Maurice
[Updated on: Tue, 10 November 2009 12:09]
Report message to a moderator
Re: [Episilon] Eugenia: Graphical Containment to represent Model Containment [message #496640 is a reply to message #496608] Tue, 10 November 2009 13:21 Go to previous message
Member
Nevermind, got it!
@gmf.compartment did the trick eg.
@gmf.compartment(foo="bar")
[Updated on: Tue, 10 November 2009 13:21]
Previous Topic:[MOFScript] Different results when running transformations programmatically and in the plugin
Next Topic:EMF Compare diff file
Current Time: Tue May 28 14:02:36 EDT 2013
Powered by FUDForum. Page generated in 0.01484 seconds
