Home » Modeling » OCL » OCL Query format
OCL Query format [message #494775] Mon, 02 November 2009 10:42 Go to next message
pkojo is currently offline pkojo
This is a query which gives number of classes in a model:
getModel().allOwnedElements()->select(oclIsTypeOf(Class))->size()
Now I want to write this query in another format
context uml::Model::findClass()
body{
is this a right way to write above query, or any one has any other solution for this.
Thanks in advance,
pkojo
Re: OCL Query format [message #494897 is a reply to message #494775] Tue, 03 November 2009 01:57 Go to previous messageGo to next message
Hi pkojo
What you are trying to do looks to be quite conventional, so it is
unclear why you need help.
If you have not tried your example, you should try it before asking for
help.
If you have tried your example, you should clearly explain what problems
you are having.
Since the syntax of body is "body optionalName : oclExpression" rather
than "body optionalName { oclExpression }" it seems clear that you have
not tried your example. The { following body should give you an obvious
syntax error to discuss.
Ed Willink
pkojo wrote:
> Now I want to write this query in another format context
> body{
> solution for this.
> Thanks in advance,
> pkojo
Re: OCL Query format [message #494943 is a reply to message #494897] Tue, 03 November 2009 05:51 Go to previous message
Hi Ed,
I tried query on OCL Interpreter Console, to count classes using
This works fine, when I use this query with context key word it gives me errors. I am very new to OCL and trying to understand how it works, I havent found any documentation which gives me hint where I use OCL query with context key word and where not.
In OCL documentation all queries are defined with context key word, if I tried same on OCL interpreter it does not work and it complains about the context key word.
Therefore I tried to compare my above query in context format like this:
body{
It will definitely complain about context keyword on OCL console.
Please little bit explain or refer me any material which explains where we can use context and where we cant.
I am sorry, I am beginner and my question is very basic, I hope you do not mind.
regards,
pokojo
Previous Topic:OCL Interpreter
Next Topic:OCL Console with history
Current Time: Sat May 25 18:07:05 EDT 2013
Powered by FUDForum. Page generated in 0.01568 seconds
