| Re: Text Fields by ID [message #495687 is a reply to message #494827] |
Thu, 05 November 2009 13:38  |
Kay-Uwe Graw Messages: 24 Registered: July 2009 |
Junior Member |
One comment to the test code. In order to avoid a dependency of your application code to any swtbot plugin by using org.eclipse.swtbot.swt.finder.utils.SWTBotPreferences.DEFAUL T_KEY, you should define your own ID_KEY and set this value in the SWTBotPreferences instead.
Kay
FUDForum. Page generated in 0.01885 seconds
