if ( pageNumber <= 0 )
int extPos = targetFile.lastIndexOf( '.' );
assert extPos != -1;
String pathName = targetFile.substring( 0, extPos );
String extName = targetFile.substring( extPos );
long pageCount = document.getPageCount( );
if ( pageCount == 1 )
options.setOutputFileName( targetFile );
task.setPageNumber( 1 ); //$NON-NLS-1$
task.render( );
else
for ( long i = 1; i <= pageCount; i++ )
String fileName = pathName + '_' + ( i ) + extName;
options.setOutputFileName( fileName );
task.setPageNumber( i );
task.render( );
You could change the ReportRunner class to use task.setPageRange instead
of task.setPageNumber. Or you could write your own RE API class to run
it how you want.
Jason
tony_ser@hotmail.com wrote:
> I have a report about 4 pages long.
> Using genreport -f pdf -o output.pdf test.rptdesign
> it generates a single pdf file.
> However, if I split run and render.
> genreport -m run test.rptdesign
> genreport -m render -f pdf -o output.pdf test.rptdocument
> It splits the output to 3 files.
> output_1.pdf
> output_2.pdf
> output_3.pdf
> Any idea?
I've just opened up an enhancement request to make this file-per-page behavior an option. I see that new users can't post links, so add https in front of this:
> in front of this:
> bugs.eclipse.org/bugs/show_bug.cgi?id=383274
