| [Acceleo] Cannot access a class's package attribute [message #494425] |
Fri, 30 October 2009 11:15  |
Peter Keller Messages: 9 Registered: October 2009 |
Junior Member |
Dear all,
Can anyone explain what is wrong with this template?
[module syntaxerr('http://www.eclipse.org/uml2/2.1.0/UML')/]
[template public syntaxerr(c : Class)]
[comment @main /]
[c.package/]
[/template]
I get a syntax error in the MTL editor, and the message:
| Quote: | token 'package' is invalid
I paused after typing 'c.' and selected 'package' from the drop-down list. If I use 'namespace' instead of 'package', it works fine.
I am using the Galileo modeling SR1 release (Linux x86_64) with Acceleo 2.6.0 installed from the Acceleo update site.
Thanks for any help,
Peter.
P.S. In case anyone is wondering what use a template like this is, I would really like to use [c.package.name/] , but need to get past this error first.
| Re: [Acceleo] Cannot access a class's package attribute [message #494441 is a reply to message #494438] |
Fri, 30 October 2009 12:11  |
Junior Member |
Hi Laurent,
I had been looking at the OCL standard, but hadn't spotted the collisions with the keywords...
Merci!
Peter.
| Laurent Goubet wrote on Fri, 30 October 2009 11:49 |
Hi Peter,
That's a collision between OCL keywords and UML choice of feature names.
To access UML's "package" attribute, you need to use "_package" in OCL.
The same will be true for most collisions such as this one.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.07963 seconds
