Home » Eclipse Projects » Web Tools Project (WTP) » Using XHTML+RDFa DOCTYPE(Editing an XHTML+RDFa document)
Using XHTML+RDFa DOCTYPE [message #493577] Mon, 26 October 2009 23:05 Go to next message
Brian Peterson is currently offline Brian Peterson
I'm trying to edit an XHTML file that has the W3C XHTML+RDFa DOCTYPE,
<!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML+RDFa 1.0//EN" "http://www.w3.org/MarkUp/DTD/xhtml-rdfa-1.dtd">
Just like this page:
http://sw.joanneum.at/scovo/schema.html
But the HTML editor doesn't seem to be picking up the DTD. I get warnings on the xmlns attribute, the title and link elements, and all of the XHTML+RDFa attributes. I'm using the JEE download of Galileo 3.5.1 and I just updated the WTP XML editor. Is there some other feature or plugin I need?
Brian
Re: Using XHTML+RDFa DOCTYPE [message #493733 is a reply to message #493577] Tue, 27 October 2009 13:34 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> plugin I need?
The HTML Editor only supports HTML 4.01 and recognized XHTML
versions; it's not built to be used with other DTDs. You'll have to
open the file using the XML Editor to use that specific DTD.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Using XHTML+RDFa DOCTYPE [message #494054 is a reply to message #493733] Wed, 28 October 2009 20:10 Go to previous messageGo to next message
I tried the XML Editor using 3.5.1, and I still get warnings about undefined attributes -- the ones defined in the XHTML+RDFa DTD. I even get an undefined warning about xmlns. I loaded the DTD itself and it validates without any errors or warnings.
Is there anything I can look at to see why the XML Editor doesn't recognize the RDFa attributes defined in the DTD? Or see what Eclipse/WTP thinks is defined in the DTD?
Brian
Re: Using XHTML+RDFa DOCTYPE [message #494063 is a reply to message #494054] Wed, 28 October 2009 22:42 Go to previous messageGo to next message
I didn't see a warning about the xmlns attribute, but I had to
specify a doctype of lowercase "html", not uppercase, and create the
root element tag accordingly. A concrete xml file would help me
with reproducing your problem. I'm unfamiliar with what is being
added by this DTD.
Nitin Dahyabhai
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Using XHTML+RDFa DOCTYPE [message #494290 is a reply to message #494063] Thu, 29 October 2009 22:02 Go to previous message
Try the page at
It is an XHMTL+RDFa document that uses the same DTD. I get similar warnings from that as I do from my own document.
Brian
Previous Topic:Make Use of Rename Events With Resource Change Events
Next Topic:What is the default url of wsdl file in eclipse-generated web services?
Current Time: Wed May 22 15:12:35 EDT 2013
Powered by FUDForum. Page generated in 0.01763 seconds
