| Re: [toplink] em.merge() changes Java Identity of detached object [message #494245 is a reply to message #494218] |
Thu, 29 October 2009 13:20  |
Sebastian Fuchs Messages: 94 Registered: July 2009 |
Member |
Hi James,
I updated to the latest toplink version but the issue is still there.
I already use field access.
Sebastian
James schrieb:
> I can't see how this could occur. Perhaps try it with EclipseLink and
> see if it has been fixed. Maybe also try the latest TopLink Essentials
> patch.
> Are you using property access or field access? I could have something
> to do with property access possibly, if you have side-effects in your
> get/set methods. Try using field access.
FUDForum. Page generated in 0.02218 seconds
