Equinox Weaving Problem [message #493930] |
Wed, 28 October 2009 10:35  |
Oliver Vesper Messages: 42 Registered: July 2009 |
Member |
Hey folks,
I'm trying to give my application a big performance boost by making the lazy-loading work. Therefore I am trying to make use of dynamic weaving. As I couldn't get it to work within my Eclipse RCP application, I set up a minimalistic Equinox test environment (very similar to [1]) which can be run outside of the Eclipse IDE - it can be downloaded from [4], the complete test case including all third-party libs can be downloaded from [5].
I followed the bundle-start-level rules described in [1], weaving is enabled in persistence.xml, the weaving-hook-fragment is registered properly to the org.eclipse.osgi master bundle... I can't see what's going wrong with my test case.
Here is the code of my bundle's Activator:
public class Activator implements BundleActivator {
public void start(final BundleContext context) throws Exception {
if (createEntityManagerFactory()) {
if (Helper.classImplementsInterface(Foo.class, PersistenceWeaved.class)) {
System.out.println("Foo is woven");
} else {
System.err.println("Foo is not woven");
if (Helper.classImplementsInterface(Bar.class, PersistenceWeaved.class)) {
System.out.println("Bar is woven");
} else {
System.err.println("Bar is not woven");
public boolean createEntityManagerFactory() {
final Properties properties = new Properties();
properties.put(PersistenceUnitProperties.CLASSLOADER, this.getClass().getClassLoader());
final EntityManagerFactory emf = new PersistenceProvider().createEntityManagerFactory("default", properties);
if (null == emf) {
return false;
final EntityManager em = emf.createEntityManager();
if (null == em) {
emf.close();
return false;
em.close();
return true;
public void stop(final BundleContext context) throws Exception {
As you can imagine, the resulting output looks like this:
Foo is not woven
Bar is not woven
The short status of my bundles looks like this:
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.6.0.v20090914
Fragments=1
1 RESOLVED org.eclipse.persistence.jpa.equinox.weaving_1.2.0.v20091016-r5565
Master=0
2 RESOLVED org.apache.derby_10.1.2.1_v200803061811
3 RESOLVED org.eclipse.persistence.jpa.equinox_1.2.0.v20091016-r5565
Master=9
4 RESOLVED org.eclipse.persistence.antlr_1.2.0.v20091016-r5565
5 RESOLVED org.eclipse.persistence.core_1.2.0.v20091016-r5565
6 RESOLVED org.eclipse.persistence.asm_1.2.0.v20091016-r5565
7 ACTIVE org.eclipse.equinox.common_3.5.100.v20090817
8 ACTIVE javax.persistence_1.99.6.v200910161445
9 ACTIVE org.eclipse.persistence.jpa_1.2.0.v20091016-r5565
Fragments=3
10 ACTIVE test.weaving_1.0.0.200910290705
My persistence.xml looks like this:
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="default" transaction-type="RESOURCE_LOCAL">
<class>test.weaving.Foo</class>
<class>test.weaving.Bar</class>
<properties>
<property name="eclipselink.weaving" value="true"/>
<property name="eclipselink.jdbc.url" value="jdbc:derby:weavingtest;create=true"/>
<property name="javax.persistence.jdbc.user" value="xyz"/>
<property name="javax.persistence.jdbc.password" value="xyz"/>
<property name="eclipselink.jdbc.driver" value="org.apache.derby.jdbc.EmbeddedDriver"/>
<property name="eclipselink.target-database" value="Derby"/>
<property name="eclipselink.jdbc.read-connections.min" value="1"/>
<property name="eclipselink.jdbc.write-connections.min" value="1"/>
<property name="eclipselink.ddl-generation" value="drop-and-create-tables"/>
<property name="eclipselink.ddl-generation.output-mode" value="database"/>
<property name="eclipselink.logging.level" value="FINE" />
<property name="eclipselink.logging.thread" value="false" />
<property name="eclipselink.logging.session" value="false" />
<property name="eclipselink.logging.exceptions" value="true" />
<property name="eclipselink.logging.timestamp" value="false"/>
</properties>
</persistence-unit>
</persistence>
Here are the versions I am currently using for this test:
- Equinox/Eclipse: 3.6M2
- Derby ([2]): 10.1.2
- EclipseLink ([3]): 1.2.0 OSGI bundles
Help is very appreciated!!!
Thanks in advance,
Oliver
[1] http://wiki.eclipse.org/EclipseLink/Examples/OSGi/Equinox_By te_Code_Weaving
[2] http://download.eclipse.org/tools/orbit/downloads/drops/R200 90825191606/
[3] http://www.eclipse.org/downloads/download.php?file=/rt/eclip selink/releases/1.2.0/eclipselink-plugins-1.2.0.v20091016-r5 565.zip
[4] http://www.filefactory.com/file/a1e99hf/n/equinox_weaving_fa ilure_zip/
[5] http://www.filefactory.com/file/a07f82b/n/equniox_weaving_fa ilure_complete_zip
[Updated on: Thu, 29 October 2009 02:23] Report message to a moderator
| Re: Equinox Weaving Problem [message #494153 is a reply to message #493930] |
Thu, 29 October 2009 08:07   |
Member |
Could it be that for some reason no service - providing the IWeaver interface - is being registered? I had a look at the output of the "services" command and couldn't find any IWeaver service. That would cause the WeaverRegistry to not process any class at all. So who's supposed to registered such a service?
Okay, it's the EquinoxInitializer located in the bundle org.eclipse.persistence.jpa.equinox. It's creating an EquinoxWeaver instance in its registerTransformer-method. So I guess that method is not being called.
Some interesting log-output:
[EL Finest]: 2009-10-29 13:42:45.041--ServerSession(25582376)--Thread(Thread[Start Level Event Dispatcher,5,main])--property=eclipselink.logging.timestamp; value=false
[EL Finest]: ServerSession(25582376)--Thread(Thread[Start Level Event Dispatcher,5,main])--property=eclipselink.logging.thread; value=false
[EL Finest]: ServerSession(25582376)--property=eclipselink.logging.session; value=false
[EL Finest]: property=eclipselink.logging.exceptions; value=true
[EL Finest]: Begin predeploying Persistence Unit default; state Initial; factoryCount 0
[EL Finest]: property=eclipselink.weaving; value=false
[EL Finest]: property=eclipselink.orm.throw.exceptions; default value=true
[EL Finer]: Searching for default mapping file in bundleresource://11.fwk16130931/
Interesting because it states that the weaving-property is set to false?!
Can anybody shed some light on this?
Thx!
[Updated on: Thu, 29 October 2009 08:46] Report message to a moderator
FUDForum. Page generated in 0.01545 seconds
