Home » Modeling » Extended Editing Framework (READ ONLY) » EEF Tutorial help?
EEF Tutorial help? [message #493625] Tue, 27 October 2009 06:17 Go to next message
Thomas is currently offline Thomas
Member
http://wiki.eclipse.org/EEF_tutorial_:_First_generation#EEF_ generation_with_EMF_treeview_editor
i am trying this tutorial. there is a class TabbedPropertiesEditionSheetPage. i cant find any information in google or somewhere else.
I need some explanation in step: EMF treeview editor modification
where is what to do? which implementions in which class, which changes in which class? are somebody able to explain it a bit more step by step?
thanks
thomas
Re: EEF Tutorial help? [message #494135 is a reply to message #493625] Thu, 29 October 2009 06:45 Go to previous message
Stephane Bouchet is currently offline Stephane Bouchet
Hi Thomas
comments below,
Sorry for the delay, but this forum is not backed up with newsgroup, and we ( EEF team ) use the EMFT newsgroup ( or forum ) to reply questions.
So please use the emft for your next questions about EEF.
This class is inside the EEF runtime plugin, you need to make a dependency with it in your plugin.xml file of your editor plugin.
The emf treeview editor is the EMF generated class that resides on the xxxxx.editor plugin, which is named xxxxEditor.java
all the modifications are made inside that class.
>thanks
>thomas
Previous Topic:EEF questions
Next Topic:Please use EMFT newsgroup or forum
Current Time: Tue May 28 13:17:15 EDT 2013
Powered by FUDForum. Page generated in 0.01605 seconds
