| Re: EEF Tutorial help? [message #494135 is a reply to message #493625] |
Thu, 29 October 2009 06:45  |
Stephane Bouchet Messages: 239 Registered: July 2009 |
Hi Thomas
comments below,
Sorry for the delay, but this forum is not backed up with newsgroup, and we ( EEF team ) use the EMFT newsgroup ( or forum ) to reply questions.
So please use the emft for your next questions about EEF.
> http://wiki.eclipse.org/EEF_tutorial_:_First_generation#EEF_ generation_with_EMF_treeview_editor
>i am trying this tutorial. there is a class TabbedPropertiesEditionSheetPage. i cant find any information in google or somewhere else.
This class is inside the EEF runtime plugin, you need to make a dependency with it in your plugin.xml file of your editor plugin.
>I need some explanation in step: EMF treeview editor modification
>where is what to do? which implementions in which class, which changes in which class? are somebody able to explain it a bit more step by step?
The emf treeview editor is the EMF generated class that resides on the xxxxx.editor plugin, which is named xxxxEditor.java
all the modifications are made inside that class.
>thanks
>thomas
FUDForum. Page generated in 0.01499 seconds
