Home » Modeling » M2T (model-to-text transformation) » [MWE]: NPE in WorkflowRunner#prepare()
[MWE]: NPE in WorkflowRunner#prepare() [message #490881] Mon, 12 October 2009 04:55 Go to next message
Andreas Werner is currently offline Andreas Werner
Member
i'm having trouble with programmatically executing the WorkflowRunner:
When executing this code, i get a NPE:
WorkflowRunner runner = new WorkflowRunner();
runner.prepare(wfFile, new NullProgressMonitor(), properties);
The reson is, that in prepare the method getVersion() is called in which
the MANIFEST.MF file cannot be resolved.
Some weeks ago everything was just fine, so i guess something is wrong with
my setup?
Has anybody an idea to solve this problem?
Kind regards,
Andreas
Re: [MWE]: NPE in WorkflowRunner#prepare() [message #491021 is a reply to message #490881] Mon, 12 October 2009 16:16 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Hi Andreas,
which version of MWE do you use? Looking at the code, I cannot imagine
#getVersion to ever throw a null pointer exception. It justs logs
something if there is no MANIFEST.MF. Are you talking about the log
output or fails your workflowrunner and does not run the workflow correctly?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Andreas Werner schrieb:
> with my setup?
> Kind regards, Andreas
Re: [MWE]: NPE in WorkflowRunner#prepare() [message #491378 is a reply to message #491021] Wed, 14 October 2009 07:55 Go to previous messageGo to next message
Member
Hello Sebastian,
I'm using org.eclispe.emf.mwe.* plugins with version 0.7.2 (200908120417).
I think the problem is (not yet tested it), that I use a class in my (generator)
plugin to execute the workflow. This class is used from another plugin (gmf
diagram). So perhaps there could be a class loading issue? What do you think?
Andreas
> Hi Andreas,
> correctly?
> Sebastian
>> WorkflowRunner: When executing this code, i get a NPE:
>> which
>> wrong with my setup?
Re: [MWE]: NPE in WorkflowRunner#prepare() [message #491690 is a reply to message #491378] Thu, 15 October 2009 09:28 Go to previous messageGo to next message
Hi Werner,
you're right - it may have something to with classloading ;-)
Does your workflow run as expected besides the log entry or does it fail?
Sebastian
> Hello Sebastian,
> (generator) plugin to execute the workflow. This class is used from
> another plugin (gmf diagram). So perhaps there could be a class loading
> Andreas
>> Hi Andreas,
>> correctly?
>> Regards,
>> Sebastian
>>> Hi,
>>> which
Re: [MWE]: NPE in WorkflowRunner#prepare() [message #493480 is a reply to message #491690] Mon, 26 October 2009 09:02 Go to previous message
Member
Hello Sebastian,
in the meantime, i reinstalled eclipse and refactored a bit and now it runs
very well...
I don't know how i achieved the erroneous behaviour (I played a bit with
Plugin->RCP->Plugin).
Thanks for your responses anyway,
Andreas ;)
> Hi Werner,
> fail?
> Sebastian
>> Hello Sebastian,
>> (200908120417).
>> Andreas
>>> Hi Andreas,
>>> imagine #getVersion to ever throw a null pointer exception. It justs
>>> logs something if there is no MANIFEST.MF. Are you talking about the
>>> log output or fails your workflowrunner and does not run the
>>> workflow correctly?
>>> Regards,
>>> Sebastian
>>>> Hi,
>>>> which
Previous Topic:Re: How to create an xpand project in galileo
Next Topic:[XPAND] accessing <<FILE ...>> from Java
Current Time: Sat May 18 07:06:17 EDT 2013
Powered by FUDForum. Page generated in 0.01852 seconds
