Home » Eclipse Projects » XML Schema Definition (XSD) » Duplicate name/target namespace error
Duplicate name/target namespace error [message #49345] Thu, 22 July 2004 16:06 Go to next message
Dennis Fuglsang is currently offline Dennis Fuglsang
Member
Ed,
We have an issue related to schema imports and includes that we need some
help with. We have a situation in which there are 3 xsd files. Schema A
imports both Schema B and C. Schema B imports Schema C. These XSDs
validate fine in XML Spy and Schema Quality Checker. However, the XSD
validation in Eclipse is complaining. I've attached sample schemas.
Import Structure:
Main ---imports---> Employee, Security
Employee ---imports---> Security
Here is the error message: XSD: The type may not have duplicate name and
target namespace 'http://www.acme/schema/Security#securityType' Main.xsd.
I suspect the Schema import/include logic in the metamodel is adding the
Security schema to Main via direct import and as a result of importing
Employee.
Is this a known issue? Has a fix been issued for this problem?
Thanks in advance,
Dennis Fuglsang
  • Attachment: Security.xsd
    (Size: 0.52KB, Downloaded 93 times)
  • Attachment: Employee.xsd
    (Size: 1.05KB, Downloaded 88 times)
  • Attachment: Main.xsd
    (Size: 1.05KB, Downloaded 123 times)
Re: Duplicate name/target namespace error [message #49437 is a reply to message #49345] Mon, 26 July 2004 08:35 Go to previous message
Eclipse User
Dennis,
I've not been able to reproduce this.
Dennis Fuglsang wrote:
>Ed,
>Import Structure:
>Employee.
>Thanks in advance,
>Dennis Fuglsang
Re: Duplicate name/target namespace error [message #589872 is a reply to message #49345] Mon, 26 July 2004 08:35 Go to previous message
Ed Merks is currently offline Ed Merks
Dennis,
>Ed,
>Import Structure:
>Employee.
>Thanks in advance,
>Dennis Fuglsang
Previous Topic:Use xsd library in java applet
Next Topic:Idea for addressing the prerequisites problem - move EMF, GEF, and XSD to Platform
Current Time: Tue May 21 11:14:12 EDT 2013
Powered by FUDForum. Page generated in 0.01852 seconds
