Home » Eclipse Projects » Eclipse Platform » Fire IncrementalProjectBuilder on Eclipse launch
Fire IncrementalProjectBuilder on Eclipse launch [message #493231] Fri, 23 October 2009 13:55 Go to next message
Louis Rose is currently offline Louis Rose
Hi all,
I've implemented an IncrementalProjectBuilder, which works when a resource changes in a project. How do I cause the builder to be run during Eclipse startup? This doesn't seem to be happening automatically...
Apologies if this has been asked before; I couldn't find an answer after Googling for quite some time.
Many thanks,
Louis.
Re: Fire IncrementalProjectBuilder on Eclipse launch [message #493242 is a reply to message #493231] Fri, 23 October 2009 15:20 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.
IProject.buid() should call all the builders on the project. (if you
really have to, then) You can extend the o.e.ui.startup to run it at
startup.
- Prakash
Platform UI Team, IBM
http://blog.eclipse-tips.com
Re: Fire IncrementalProjectBuilder on Eclipse launch [message #493284 is a reply to message #493242] Sat, 24 October 2009 05:24 Go to previous message
Thanks Prakash, I'll take the IStartUp route. Just wanted to check there wasn't a way to achieve this with builder API.
Previous Topic:Java file mapping to there generated class files in Eclipse 2.0, 2.1 and 3.0 versions
Next Topic:Command line building with antRunner and "external" in bundle-classpath
Current Time: Tue May 21 19:48:08 EDT 2013
Powered by FUDForum. Page generated in 0.02018 seconds
