| java.lang.NullPointerException [message #492642] |
Wed, 21 October 2009 04:48  |
Mikael Petterson Messages: 150 Registered: July 2009 |
I changed to using jdk 1.5 since I read that support for 1.4 seems to be removed ( that might be the reson for my problems in previous post).
I am still doing the profiling locally.
GUI: Fetching children of data collector ... 0%
It hangs there forever and log is filled with ( see below).
br,
//miakel
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@b3f220" java.lang.NullPointerException
at org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.versionIsAtLeast(AgentControllerDescriptor.java:67)
at org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.isVersionAtLeast(AgentControllerDescriptor.java:194)
at org.eclipse.hyades.execution.local.file.FileManagerFactory$3 .run(FileManagerFactory.java:413)
at org.eclipse.hyades.execution.core.task.ReusableThread.run(Re usableThread.java:131)
at java.lang.Thread.run(Thread.java:619)
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@337ff4" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@d5a66a" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@12ab673" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@10f144e" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@985bf9" java.lang.NullPointerException
| Re: java.lang.NullPointerException [message #555517 is a reply to message #492642] |
Thu, 26 August 2010 17:59   |
Matt Messages: 2 Registered: August 2010 |
Junior Member |
I installed TPTP 4.6.2 today. It worked initially without problems, and then started hanging at the Monitor window. The exceptions I saw in the logs were same as described above.
The problem turned out to be simple. Integrated Agent Controller runs on port 10002 by default. Somehow, though I shut down Eclipse, Agent Controller didn't die, it was still running, listening on 10002. Try this to see if it's running
telnet localhost 10002
Once I killed that process, I started up Eclipse, and TPTP worked again.
TPTP is great. Suggestions to TPTP guys:
1. There appear to be cases where Eclipse can exit, but the Controller lingers on. Should be fixed.
2. If there was anything like "TPTP controller is unable to establish connection on port 10002" in the logs, I would've figured this out in 5 minutes instead of half a day.
-Matt
| Re: java.lang.NullPointerException [message #555520 is a reply to message #495057] |
Thu, 26 August 2010 18:02  |
Junior Member |
-Matt
FUDForum. Page generated in 0.01635 seconds
