| Create associations in profile definiton [message #491967] |
Fri, 16 October 2009 15:47  |
Timothy Marc Messages: 547 Registered: July 2009 |
Hi all,
i was wondering why it is not possible to draw associations within a
profile definitio diagram? Since Stereotypes are subclasses of classes
and the spec doesn't prohibits the usage of associations between
stereotypes, it should be possible to draw these associations with
UMLDiagrams...
Any comment?!
Timothy
| Re: Create associations in profile definiton [message #492632 is a reply to message #492009] |
Wed, 21 October 2009 03:58  |
Hi Tatiana,
wouldn't it be better to merge the palettes from class and profile
diagram. For me, it didn't make sense to separate them, because defining
a profile is quite similar to defining class diagrams...
Thanks Timothy
Tatiana Fesenko schrieb:
> Hi Timothy,
> There is https://bugs.eclipse.org/bugs/show_bug.cgi?id=174957 in UML2
> Tools bugzilla for Association support in Profile diagrams. There is no
> figures in UML specification showing association in a profile, that's
> why associations were not implemented in initial set of supported
> metaclasses in profile diagrams.
> However, you can still create and edit associations when you open Class
> diagram editor for a profile or in the UML editor.
> Best wishes,
> Tanya.
| Re: Create associations in profile definiton [message #625094 is a reply to message #492009] |
Hi Tatiana,
Thanks Timothy
> Hi Timothy,
> Best wishes,
> Tanya.
FUDForum. Page generated in 0.05595 seconds
