Home » Eclipse Projects » EclipseLink » Related records as a non-entity collection(How to load related table records as a set of a basic (non-entity) type?)
icon5.gif  Related records as a non-entity collection [message #491968] Fri, 16 October 2009 15:56 Go to next message
LexLythius  is currently offline LexLythius
I have a table FOO represented by an entity class Foo. Each row in FOO can have 0 or more related rows in table FOO_TS. The latter is a very simple table with only one value field (a timestamp) and a key field (fooId) to associate with the main table.
Question is: how can I get all corresponding FOO_TS timestamps into a collection field in class Foo, without creating an entity class for those timestamps? It would be a burden to add a PK field+index into table BAR for just that purpose. By the same token, I want to avoid making a FooTimestamp entity with a composite PK or something of that sort.
Something like this:
@Entity
@Table(name="FOO")
class Foo {
  @Id
  private Integer fooId;
  private Set<Timestamp> timestamps = new HashSet<Timestamp>();
Thanks for any help
Re: Related records as a non-entity collection [message #492235 is a reply to message #491968] Mon, 19 October 2009 10:37 Go to previous message
James Sutherland is currently offline James Sutherland
In EclipseLink you can use an @BasicCollection for this, or in EclipseLink 1.2 and JPA 2.0 you can use an @ElementCollection.
http://en.wikibooks.org/wiki/Java_Persistence/ElementCollect ion#Basic_Collections
James : Wiki : Book : Blog
Previous Topic:Random deadlock/hang during commit in EJB3 application
Next Topic:be able to specify JDBC driver jar w/o adding it to manifest
Current Time: Tue May 21 18:08:36 EDT 2013
Powered by FUDForum. Page generated in 0.10951 seconds
